No High/Low Humidity....
AAMFlyer
Post by AAMFlyer »
I've recently added the high low humidity in WDL but it doesn't have data.... Everything else works and is populated - but Hi/Lo humidity won't get data - even after recomputation, reboot, etc.... Is this supported as the data is there in the graphs etc..... I'm thinking it's just a little bug - anyone else have this issue...
G
Re:No High/Low Humidity....
I don't know of min/max humidity being part of clientraw-files. Could you please give a bit more detail? My documentation of clientraw files does not state min/max values on humidity for a given day/month/year/alltime.
AAMFlyer
Post by AAMFlyer »
I'll take a look in the clientraw files - it's an option in the WDL Configurator/Setup from WDL's side...but perhaps is missing elsewhere - I'll take a look tomorrow and get back to you! Thanks!!!!
AAMFlyer
Post by AAMFlyer »
You are correct Boris - WDL doesn't have a feature yet for Min/Max Humidity....weird!
Gregg
