Boris - Possible Wind Direction Bug....
AAMFlyer
Post by AAMFlyer »
Boris - I think I may have found a small bug in the Avg Wind Direction - everything else is working great!
The avg wind shows W or 270d even though it has been E.... I have attached the pics showing the graph vs what the guage is showing....the clientraw.txt file shows the same too:
117 Wind Avg Dir D 270.0° (W)
AAMFlyer
Re:Boris - Possible Wind Direction Bug....
Post by AAMFlyer »
AAMFlyer
Post by AAMFlyer »
It's basically stuck on West.....
The green arrow representing actual wind direction looks ok to me.
The red tip displays average wind direction. Meteohub puts the average wind direction of the day in there. So don't expect timely changes. The parameter is named "day1_wind0_maindir_deg" in Meteohub variable list. You can ask for the value by "http://yourmeteohubip/meteograph.cgi?te ... aindir_deg"
Regards,
Boris
AAMFlyer
Post by AAMFlyer »
Okay - that explains it then! Thanks!
