I'm new in Meteohub (2 days :) ). Before this I was running WD. Up to now, except for a couple of minor things, Meteohub is running smoothly on a NSLU2 connected to a OS WMR200 and sending data to my web page (including WDL; the page is www.juanalberto.arrakis.es/meteo, just in case you want to have a look at it) and to the Spanish Meteoclimatic station.
The only problem I have now is that I have lost the year and all-time records I had in WD (i.e. total year rainfall, min and max temp, etc.).
Probably you have already discussed this issue in a previous post in this forum, but I cannot find it.
I managed to set these record values temporarily by manually editing the hist-alltime and year1-hist (I'm not sure of the actual names) files under the meteohub weather directory, but these files are changed every time meteohub recomputes data, so my changes are lost.
I also read a post in the Meteoclimatic forum about a way to do this by setting "fake" calibrations for the initial values, but this also does not work on my installation.
So, does anybody have a clue on how to set historical records in Meteohub (older than the date when Meteohub starts running on my installation)?
Thank you very much in advance.
Migrating from WD to Meteohub: setting alltime/year hist in
