Sensor
simonik
Sensor
Post by simonik »
I instaled Wantage Pro and NSLU. NSLU detected Vantage but did not detect sensor. I received error : connect socket 127.0.0.1:5555 :Connection refused. I try refresh button and error disappear but I did not get list of sensor.
Error: "connect socket 127.0.0.1:5555 :Connection refused" is shown again.
What can I try?
Re:Sensor
Any messages in "meteohub log" on Meteohub's "Logfiles" page?
Could you please provide a screen dump of your settings on Meteohub's "weather station" page?
simonik
Re:Sensor
Post by simonik »
Dear Sir,
I am sending you JPG and log.
Thanks [file name=log-e376bf1edcebe60dba8e1cc1ce47896e.txt size=82265]http://www.meteohub.de/joomla/images/fb ... 47896e.txt[/file] Image
simonik
Re:Sensor
Post by simonik »
Vantage Image
Re:Sensor
That looks ok.
If you don't mind I would like to login to your Meteohub to inspect some details. To let me in, you have to forward ports 22 and 7777 at your router to LAN IP of Meteohub. Having done that, please send the WAN IP to "info(at)meteohub.de". That would allow me to login.
simonik
Re:Sensor
Post by simonik »
Dear Sir,
I am sorry,I have not external IP address. Log that I sent you cannot help you?
Re:Sensor
Well, the screen dumps tell me that the weather station settings seem to be ok. It is hard guess work to find out why the data logger does not start.
Could you please post the content of "meteohub log". You get this as one of the log files on Meteohub's "Log File" page.
Vyborg
Re:Sensor
Post by Vyborg »
i have the same problem from yesterday, it shows the same message-error. :blink:
simonik
Re:Sensor
Post by simonik »
Thank you very much for your answer.
I have solved this problem. I made new image copy to my USB stick and aquipment is working.I found out if image copy is bad the samples of graphs are not available.
Best regards
Vyborg
Re:Sensor
Post by Vyborg »
I don't understand, Simonik. Had you a problem with the sensors or with the graphs?
How can a new image copy solve the problem about the undetected Davis sensors?
