NSLU2 updated to V4.2 sensors page error connect socket 127.
junkycosmos
Post by junkycosmos »
Have been using the NSLU2 with WRM-200 for almost a year now. Was on 2.6 then updated to 3.1 and then up to 4.2c. Now since moving to 4.2 I am not able to specify any sensors. Have tried redoing firmware via browser install, also by copying into the transfer folder and by the 2 memory stick method. Notably I also now get an error when trying to copy the firmware into the \\transfer folder that acess is denied.
Ofcourse the main problem is that I cannot specify any sensors....
"Warning: Weather station does not have a sensor assigned
error connect socket 127.0.0.1:5555 :Connection refused
Warning: Data logging has been halted."
Re:NSLU2 updated to V4.2 sensors page error connect socket 1
Could you please provide a screen dump of your "weather station" page? What does "meteohub log" tell us on "Log Files" page?
junkycosmos
Thanks for the reply. Just had to power cycle the NSLU as it was giving me Page Cannot Be Displayed. (its done that a few times after I've power cycled the WRM-200). It did boot right up and let me login.
**WEATHER STATION PAGE ** jpg attached
***System Log***
Apr 28 12:22:12 (none) syslog.info syslogd started: BusyBox v1.2.1
Apr 28 12:22:12 (none) user.notice kernel: klogd started: BusyBox v1.2.1 (2007.12.25-11:17+0000)
Apr 28 12:22:12 (none) user.notice kernel: Linux version 2.6.21.7 (slug@otto) (gcc version 4.1.2) #1 PREEMPT Mon Dec 24 23:12:24 UTC 2007
Apr 28 12:22:12 (none) user.warn kernel: CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE), cr=000039ff
Apr 28 12:22:12 (none) user.warn kernel: Machine: Linksys NSLU2
Apr 28 12:22:12 (none) user.warn kernel: Memory policy: ECC disabled, Data cache writeback
Apr 28 12:22:12 (none) user.debug kernel: On node 0 totalpages: 8192
Apr 28 12:22:12 (none) user.debug kernel: DMA zone: 64 pages used for memmap
Apr 28 12:22:12 (none) user.debug kernel: DMA zone: 0 pages reserved
Apr 28 12:22:12 (none) user.debug kernel: DMA zone: 8128 pages, LIFO batch:0
Apr 28 12:22:12 (none) user.debug kernel: Normal zone: 0 pages used for memmap
Apr 28 12:22:12 (none) user.warn kernel: CPU0: D VIVT undefined 5 cache
Apr 28 12:22:12 (none) user.warn kernel: CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Apr 28 12:22:12 (none) user.warn kernel: CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
Apr 28 12:22:12 (none) user.warn kernel: Built 1 zonelists. Total pages: 8128
Apr 28 12:22:12 (none) user.notice kernel: Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
Apr 28 12:22:12 (none) user.info kernel: IRQ lockup detection disabled
Apr 28 12:22:12 (none) user.warn kernel: PID hash table entries: 128 (order: 7, 512 bytes)
Apr 28 12:22:12 (none) user.warn kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Apr 28 12:22:12 (none) user.warn kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Apr 28 12:22:12 (none) user.info kernel: Memory: 32MB = 32MB total
Apr 28 12:22:12 (none) user.notice kernel: Memory: 30292KB available (1912K code, 153K data, 84K init)
Apr 28 12:22:12 (none) user.debug kernel: Calibrating delay loop... 132.71 BogoMIPS (lpj=663552)
Apr 28 12:22:12 (none) user.warn kernel: Mount-cache hash table entries: 512
Apr 28 12:22:12 (none) user.info kernel: CPU: Testing write buffer coherency: ok
Apr 28 12:22:12 (none) user.info kernel: NET: Registered protocol family 16
Apr 28 12:22:12 (none) user.warn kernel: IXP4xx: Using 16MiB expansion bus window size
Apr 28 12:22:12 (none) user.warn kernel: PCI: IXP4xx is host
Apr 28 12:22:12 (none) user.warn kernel: PCI: IXP4xx Using direct access for memory space
Apr 28 12:22:12 (none) user.info kernel: PCI: bus0: Fast back to back transfers disabled
Apr 28 12:22:12 (none) user.info kernel: dmabounce: registered device 0000:00:01.0 on pci bus
Apr 28 12:22:12 (none) user.info kernel: dmabounce: registered device 0000:00:01.1 on pci bus
Apr 28 12:22:12 (none) user.info kernel: dmabounce: registered device 0000:00:01.2 on pci bus
Apr 28 12:22:12 (none) user.notice kernel: SCSI subsystem initialized
Apr 28 12:22:12 (none) user.info kernel: usbcore: registered new interface driver usbfs
Apr 28 12:22:12 (none) user.info kernel: usbcore: registered new interface driver hub
Apr 28 12:22:12 (none) user.info kernel: usbcore: registered new device driver usb
Apr 28 12:22:12 (none) user.info kernel: Time: OSTS clocksource has been installed.
Apr 28 12:22:12 (none) user.info kernel: NET: Registered protocol family 2
Apr 28 12:22:12 (none) user.warn kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Apr 28 12:22:12 (none) user.warn kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Apr 28 12:22:12 (none) user.warn kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Apr 28 12:22:12 (none) user.info kernel: TCP: Hash tables configured (established 1024 bind 1024)
Apr 28 12:22:12 (none) user.info kernel: TCP reno registered
Apr 28 12:22:12 (none) user.warn kernel: NetWinder Floating Point Emulator V0.97 (double precision)
Apr 28 12:22:12 (none) user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Apr 28 12:22:12 (none) user.info kernel: io scheduler noop registered
Apr 28 12:22:12 (none) user.info kernel: io scheduler deadline registered (default)
Apr 28 12:22:12 (none) user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
Apr 28 12:22:12 (none) user.info kernel: serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
Apr 28 12:22:12 (none) user.info kernel: serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
Apr 28 12:22:12 (none) user.warn kernel: RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
Apr 28 12:22:12 (none) user.info kernel: IXP4XX NPE driver Version 0.3.0 initialized
Apr 28 12:22:12 (none) user.info kernel: NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
Apr 28 12:22:12 (none) user.info kernel: IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Apr 28 12:22:12 (none) user.debug kernel: IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
Apr 28 12:22:12 (none) user.warn kernel: Intel/Sharp Extended Query Table at 0x0031
Apr 28 12:22:12 (none) user.info kernel: Using buffer write method
Apr 28 12:22:12 (none) user.notice kernel: cfi_cmdset_0001: Erase suspend on write enabled
Apr 28 12:22:12 (none) user.debug kernel: erase region 0: offset=0x0,size=0x20000,blocks=64
Apr 28 12:22:12 (none) user.notice kernel: Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
Apr 28 12:22:12 (none) user.notice kernel: 6 RedBoot partitions found on MTD device IXP4XX-Flash.0
Apr 28 12:22:12 (none) user.notice kernel: Creating 6 MTD partitions on "IXP4XX-Flash.0":
Apr 28 12:22:12 (none) user.notice kernel: 0x00000000-0x00040000 : "RedBoot"
Apr 28 12:22:12 (none) user.info kernel: nslu2 mac: 00:0f:66:7b:fa:a0
Apr 28 12:22:12 (none) user.notice kernel: 0x00040000-0x00060000 : "SysConf"
Apr 28 12:22:12 (none) user.notice kernel: 0x00060000-0x00080000 : "Loader"
Apr 28 12:22:12 (none) user.notice kernel: 0x00080000-0x00180000 : "Kernel"
Apr 28 12:22:12 (none) user.notice kernel: 0x00180000-0x007e0000 : "Flashdisk"
Apr 28 12:22:12 (none) user.notice kernel: 0x007e0000-0x00800000 : "FIS directory"
Apr 28 12:22:12 (none) user.warn kernel: npe: searching for firmware...
Apr 28 12:22:12 (none) user.info kernel: npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
Apr 28 12:22:12 (none) user.info kernel: Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
Apr 28 12:22:12 (none) user.info kernel: Initializing USB Mass Storage driver...
Apr 28 12:22:12 (none) user.info kernel: usbcore: registered new interface driver usb-storage
Apr 28 12:22:12 (none) user.info kernel: USB Mass Storage support registered.
Apr 28 12:22:12 (none) user.info kernel: input: ixp4xx beeper as /class/input/input0
Apr 28 12:22:12 (none) user.info kernel: i2c /dev entries driver
Apr 28 12:22:12 (none) user.info kernel: x1205 0-006f: chip found, driver version 1.0.7
Apr 28 12:22:12 (none) user.info kernel: x1205 0-006f: rtc core: registered x1205 as rtc0
Apr 28 12:22:12 (none) user.info kernel: Registered led device: ready
Apr 28 12:22:12 (none) user.info kernel: Registered led device: status
Apr 28 12:22:12 (none) user.info kernel: Registered led device: disk-1
Apr 28 12:22:12 (none) user.info kernel: >Registered led device: disk-2
Apr 28 12:22:12 (none) user.info kernel: TCP cubic registered
Apr 28 12:22:12 (none) user.info kernel: NET: Registered protocol family 17
Apr 28 12:22:12 (none) user.info kernel: XScale DSP coprocessor detected.
Apr 28 12:22:12 (none) user.info kernel: x1205 0-006f: setting the system clock to 2009-04-28 12:21:31 (1240921291)
Apr 28 12:22:12 (none) user.warn kernel: VFS: Mounted root (jffs2 filesystem).
Apr 28 12:22:12 (none) user.info kernel: Freeing init memory: 84K
Apr 28 12:22:12 (none) user.warn kernel: PCI: enabling device 0000:00:01.2 (0140 -> 0142)
Apr 28 12:22:12 (none) user.info kernel: ehci_hcd 0000:00:01.2: EHCI Host Controller
Apr 28 12:22:12 (none) user.info kernel: ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
Apr 28 12:22:12 (none) user.info kernel: ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
Apr 28 12:22:12 (none) user.info kernel: ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Apr 28 12:22:12 (none) user.info kernel: usb usb1: configuration #1 chosen from 1 choice
Apr 28 12:22:12 (none) user.info kernel: hub 1-0:1.0: USB hub found
Apr 28 12:22:12 (none) user.info kernel: hub 1-0:1.0: 5 ports detected
Apr 28 12:22:12 (none) user.debug kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
Apr 28 12:22:12 (none) user.warn kernel: PCI: enabling device 0000:00:01.0 (0140 -> 0142)
Apr 28 12:22:12 (none) user.info kernel: ohci_hcd 0000:00:01.0: OHCI Host Controller
Apr 28 12:22:12 (none) user.info kernel: ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
Apr 28 12:22:12 (none) user.info kernel: ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
Apr 28 12:22:12 (none) user.info kernel: usb usb2: configuration #1 chosen from 1 choice
Apr 28 12:22:12 (none) user.info kernel: hub 2-0:1.0: USB hub found
Apr 28 12:22:12 (none) user.info kernel: hub 2-0:1.0: 3 ports detected
Apr 28 12:22:12 (none) user.warn kernel: PCI: enabling device 0000:00:01.1 (0140 -> 0142)
Apr 28 12:22:12 (none) user.info kernel: ohci_hcd 0000:00:01.1: OHCI Host Controller
Apr 28 12:22:12 (none) user.info kernel: ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
Apr 28 12:22:12 (none) user.info kernel: ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
Apr 28 12:22:12 (none) user.info kernel: usb usb3: configuration #1 chosen from 1 choice
Apr 28 12:22:12 (none) user.info kernel: hub 3-0:1.0: USB hub found
Apr 28 12:22:12 (none) user.info kernel: hub 3-0:1.0: 2 ports detected
Apr 28 12:22:12 (none) user.info kernel: usb 1-2: new high speed USB device using ehci_hcd and address 3
Apr 28 12:22:12 (none) user.info kernel: usb 1-2: configuration #1 chosen from 1 choice
Apr 28 12:22:12 (none) user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Apr 28 12:22:12 (none) user.debug kernel: usb-storage: device found at 3
Apr 28 12:22:12 (none) user.debug kernel: usb-storage: waiting for device to settle before scanning
Apr 28 12:22:12 (none) user.info kernel: usb 2-1: new low speed USB device using ohci_hcd and address 2
Apr 28 12:22:12 (none) user.info kernel: usb 2-1: configuration #1 chosen from 1 choice
Apr 28 12:22:12 (none) user.notice kernel: scsi 0:0:0:0: Direct-Access Kingmax USB2.0 FlashDisk 0.00 PQ: 0 ANSI: 2
Apr 28 12:22:12 (none) user.notice kernel: SCSI device sda: 3948543 512-byte hdwr sectors (2022 MB)
Apr 28 12:22:12 (none) user.notice kernel: sda: Write Protect is off
Apr 28 12:22:12 (none) user.debug kernel: sda: Mode Sense: 00 00 00 00
Apr 28 12:22:12 (none) user.err kernel: sda: assuming drive cache: write through
Apr 28 12:22:12 (none) user.info kernel: sda: sda1 sda2 sda3
Apr 28 12:22:12 (none) user.notice kernel: sd 0:0:0:0: Attached scsi removable disk sda
Apr 28 12:22:12 (none) user.debug kernel: usb-storage: device scan complete
Apr 28 12:22:12 (none) user.info kernel: kjournald starting. Commit interval 5 seconds
Apr 28 12:22:12 (none) user.warn kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Apr 28 12:22:12 (none) user.info kernel: EXT3 FS on sda1, internal journal
Apr 28 12:22:12 (none) user.debug kernel: ext3_orphan_cleanup: deleting unreferenced inode 26649
Apr 28 12:22:12 (none) user.info kernel: EXT3-fs: sda1: 1 orphan inode deleted
Apr 28 12:22:12 (none) user.info kernel: EXT3-fs: recovery complete.
Apr 28 12:22:12 (none) user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
Apr 28 12:22:12 (none) user.info kernel: IXP4XX Q Manager 0.2.1 initialized.
Apr 28 12:22:12 (none) user.info kernel: ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
Apr 28 12:22:12 (none) user.info kernel: usbcore: registered new interface driver hiddev
Apr 28 12:22:12 (none) user.info kernel: hiddev96: USB HID v1.10 Device [Universal Bridge] on usb-0000:00:01.0-1
Apr 28 12:22:12 (none) user.info kernel: usbcore: registered new interface driver usbhid
Apr 28 12:22:12 (none) user.info kernel: drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Apr 28 12:22:12 (none) user.info kernel: EXT3 FS on sda3, internal journal
Apr 28 12:22:12 (none) user.info kernel: Adding 131064k swap on /dev/sda2. Priority:-1 extents:1 across:131064k
Apr 28 12:22:13 (none) user.info kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Apr 28 12:22:13 (none) user.debug kernel: Link of eth0 is full-duplex
Apr 28 12:22:16 (none) user.warn kernel: IXP4xx Watchdog Timer: heartbeat 60 sec
Apr 28 12:22:17 (none) user.info kernel: usbcore: registered new interface driver usbserial
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
Apr 28 12:22:17 (none) user.info kernel: usbcore: registered new interface driver usbserial_generic
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
Apr 28 12:22:17 (none) user.info kernel: usbcore: registered new interface driver pl2303
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
Apr 28 12:22:17 (none) user.info kernel: usbcore: registered new interface driver cp2101
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
Apr 28 12:22:17 (none) user.info kernel: usbcore: registered new interface driver ftdi_sio
Apr 28 12:22:17 (none) user.info kernel: drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
Apr 28 12:22:18 (none) user.notice root: restart with recomputation of data (spontaneous reboot, reboot after shutdown, reboot after update).
Apr 28 12:22:18 (none) daemon.info init: Entering runlevel: 3
Apr 28 12:22:19 (none) auth.info sshd[1012]: Server listening on 0.0.0.0 port 22.
Apr 28 12:22:24 (none) daemon.crit thttpd[1085]: socket :: - Address family not supported by protocol
Apr 28 12:22:24 (none) daemon.notice thttpd[1085]: thttpd/2.25b 29dec2003 starting on port 80
Apr 28 12:22:24 (none) daemon.warn thttpd[1085]: started as root without requesting chroot(), warning only
Apr 28 12:22:25 (none) user.info kernel: sd 0:0:0:0: SCSI error: return code = 0x08000002
Apr 28 12:22:25 (none) user.info kernel: sda: Current: sense key=0x7
Apr 28 12:22:25 (none) user.info kernel: ASC=0x27 ASCQ=0x0
Apr 28 12:22:25 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1936280
Apr 28 12:22:25 (none) user.err kernel: Buffer I/O error on device sda3, logical block 102771
Apr 28 12:22:25 (none) user.warn kernel: lost page write due to I/O error on sda3
Apr 28 12:22:25 (none) user.warn kernel: end_request: I/O error, dev sda, sector 2153544
Apr 28 12:22:25 (none) daemon.crit thttpdbackup[1092]: socket :: - Address family not supported by protocol
Apr 28 12:22:25 (none) user.err kernel: Buffer I/O error on device sda3, logical block 129929
Apr 28 12:22:25 (none) user.err kernel: Aborting journal on device sda3.
Apr 28 12:22:25 (none) user.warn kernel: __journal_remove_journal_head: freeing b_committed_data
Apr 28 12:22:25 (none) daemon.notice thttpdbackup[1092]: thttpd/2.25b 29dec2003 starting on port 7777
Apr 28 12:22:25 (none) daemon.warn thttpdbackup[1092]: started as root without requesting chroot(), warning only
Apr 28 12:22:26 (none) user.crit kernel: ext3_abort called.
Apr 28 12:22:26 (none) user.crit kernel: EXT3-fs error (device sda3): ext3_journal_start_sb: Detected aborted journal
Apr 28 12:22:26 (none) user.crit kernel: Remounting filesystem read-only
Apr 28 12:22:26 (none) daemon.notice ntpd[1103]: ntpd 4.2.2p3@1.1577 Sat Feb 9 23:00:06 UTC 2008 (1)
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: precision = 12.000 usec
Apr 28 12:22:26 (none) daemon.debug ntpd[1104]: ntp_io: estimated max descriptors: 1024, initial socket boundary: 16
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: Listening on interface wildcard, 0.0.0.0#123 Disabled
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: Listening on interface lo, 127.0.0.1#123 Enabled
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: Listening on interface eth0, 192.168.1.78#123 Enabled
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: Listening on interface eth0:0, 192.168.1.77#123 Enabled
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: kernel time sync status 0040
Apr 28 12:22:26 (none) daemon.err ntpd[1104]: Cannot open log file /data/log/ntp.log
Apr 28 12:22:26 (none) daemon.info ntpd[1104]: frequency initialized 5.920 PPM from /var/spool/ntp/ntp.drift
Apr 28 12:22:26 (none) cron.info /usr/sbin/cron[1116]: (CRON) STARTUP (fork ok)
Apr 28 12:22:27 (none) cron.info /usr/sbin/cron[1116]: (root.new) ORPHAN (no passwd entry)
Apr 28 12:22:27 (none) cron.info /usr/sbin/cron[1116]: (root.boot) ORPHAN (no passwd entry)
Apr 28 12:22:36 (none) user.info kernel: sd 0:0:0:0: Device not ready: <6>: Current: sense key=0x2
Apr 28 12:22:36 (none) user.info kernel: ASC=0x3a ASCQ=0x0
Apr 28 12:22:36 (none) user.warn kernel: end_request: I/O error, dev sda, sector 1900560
Apr 28 12:22:36 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98306
Apr 28 12:22:36 (none) user.warn kernel: lost page write due to I/O error on sda3
Apr 28 12:22:36 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98307
Apr 28 12:22:36 (none) user.err kernel: Buffer I/O error on device sda3, logical block 98308
Apr 28 12:22:36 (none) user.warn kernel: end_request: I/O error, dev sda, sector 2113536
Apr 28 12:22:36 (none) user.err kernel: Buffer I/O error on device sda3, logical block 124928
Apr 28 12:22:41 (none) user.debug kernel: usb 2-1: usbfs: USBDEVFS_CONTROL failed cmd hidlog rqt 33 rq 9 len 8 ret -110
Apr 28 12:23:00 (none) cron.info /USR/SBIN/CRON[1152]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:24:00 (none) cron.info /USR/SBIN/CRON[1190]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:24:00 (none) cron.info /USR/SBIN/CRON[1192]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
Apr 28 12:25:00 (none) cron.info /USR/SBIN/CRON[1205]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:25:00 (none) cron.info /USR/SBIN/CRON[1202]: (root) CMD (/home/meteohub/wmr928fullevalwrapper >/dev/null 2>>/data/log/messages)
Apr 28 12:25:00 (none) cron.info /USR/SBIN/CRON[1206]: (root) CMD (/bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1)
Apr 28 12:25:00 (none) cron.info CRON[1201]: (root) MAIL (mailed 65 bytes of output but got status 0x0001 )
Apr 28 12:26:00 (none) cron.info /USR/SBIN/CRON[1224]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:26:01 (none) daemon.info thttpd[1085]: spawned CGI process 1226 for file 'cgi-bin/meteohub.cgi'
Apr 28 12:26:33 (none) daemon.info thttpd[1085]: spawned CGI process 1259 for file 'cgi-bin/meteohub.cgi'
Apr 28 12:26:41 (none) daemon.info thttpd[1085]: spawned CGI process 1292 for file 'cgi-bin/meteohub.cgi'
Apr 28 12:26:48 (none) daemon.info ntpd[1104]: synchronized to 192.53.103.108, stratum 1
Apr 28 12:26:49 (none) daemon.notice ntpd[1104]: time reset +1.215431 s
Apr 28 12:26:49 (none) daemon.notice ntpd[1104]: kernel time sync enabled 0001
Apr 28 12:27:01 (none) cron.info /USR/SBIN/CRON[1319]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:27:01 (none) cron.info /USR/SBIN/CRON[1321]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
Apr 28 12:28:00 (none) cron.info /USR/SBIN/CRON[1328]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -x -c min1 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -e /home/meteohub/wswin.conf -E /home/meteohub/wd.conf)
Apr 28 12:28:00 (none) cron.info /USR/SBIN/CRON[1330]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:29:00 (none) cron.info /USR/SBIN/CRON[1337]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:30:00 (none) cron.info /USR/SBIN/CRON[1345]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:30:00 (none) cron.info /USR/SBIN/CRON[1347]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
Apr 28 12:30:00 (none) cron.info /USR/SBIN/CRON[1342]: (root) CMD (/home/meteohub/wmr928fullevalwrapper >/dev/null 2>>/data/log/messages)
Apr 28 12:30:00 (none) cron.info /USR/SBIN/CRON[1348]: (root) CMD (/bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1)
Apr 28 12:31:00 (none) cron.info /USR/SBIN/CRON[1370]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Apr 28 12:31:00 (none) cron.info /USR/SBIN/CRON[1368]: (root) CMD (/usr/bin/nice /home/meteohub/wmr928eval -c min5 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf)
Apr 28 12:31:04 (none) daemon.info thttpd[1085]: spawned CGI process 1374 for file 'cgi-bin/meteohub.cgi'
Apr 28 12:31:07 (none) daemon.info thttpd[1085]: spawned CGI process 1396 for file 'cgi-bin/meteohub.cgi'
***SMB Server Log***
[2009/04/28 12:22:22, 0] smbd/server.c:main(881)
standard input is not a socket, assuming -D option
[2009/04/28 12:22:24, 1] lib/account_pol.c:account_policy_get(329)
account_policy_get: tdb_fetch_uint32 failed for field 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 8 (bad lockout attempt), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for field 10 (refuse machine password change), returning 0
thanks! Image
Weather station settings look ok.
Could you please also add the "meteohub log"? It is the third logfile from the drop-down menu.
junkycosmos
meteohub log is empty, tried the refresh a few times Image
YJB
Post by YJB »
I might be wrong, but are you sure that you don't have any issues with your memory stick?
I can't recall seeing these kind of messages on my NSLU
Your USB stick is faulty. Please try a new one.
junkycosmos
Thank you both! Makes sense given how much trouble I had getting the image onto it. The disk image tool from winxp kept failing between 20% & 80%. I finally did get it to install by doing the two stick method (placing v4.2c on 256MB stick and then having NSLU copy to the main 2 gig stick). It took 60+ mins to copy but then Meteohub was bootable. Weird part here is that I was on v2.6 (or so) with no issues other than know ones for 9 months or so.
Will try a different memory stick and get back to you here.
Thanks again
Vyborg
Post by Vyborg »
I get the same message "error socket 127.0.0.1:5555" and i've lost the signal of all my sensors. i find this errors on my meteohub log. What's happened? Thanks
logger (29.04.2009 01:49:56): data logger started.
logger (29.04.2009 01:49:58): connect station 0 (Vantage).
logger (29.04.2009 01:49:59): station 0 (Vantage), syncing.
logger (29.04.2009 01:49:59): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 01:49:59): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 01:49:59): station 0 (Vantage), ready logging data.
wmr928eval (29.04.2009 01:50:00): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:00): error while opening file /data/weather//hist-day1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:00): error while opening file /data/weather//hist-hour1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:00): error while opening file /data/weather//hist-last24h for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:00): error while opening file /data/weather//hist-last60m for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:01): error while opening file /data/weather//hist-last15m for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 01:50:01): error while opening file /data/weather//seq-hour1 for writing: Input/output error: Input/output error
logger (29.04.2009 01:50:04): failed making directory /data/weather/200904: In
YJB
Post by YJB »
I managed to read your log entries, the font is a kind of small to say so...
I'm wondering what your system log is saying.
Right now I see 2 possibilities
- Faulty disk/memory stick
= Full disk/memory disk.
Vyborg
Post by Vyborg »
Thanks YJB, this is the entire meteohub log and system too. Would be a mess to change my memory stick once again (third time..)
B)
Vyborg
Post by Vyborg »
logger (29.04.2009 10:11:41): connect station 0 (Vantage).
logger (29.04.2009 10:11:42): station 0 (Vantage), syncing.
logger (29.04.2009 10:11:42): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:11:42): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:11:42): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:11:48): failed making directory /data/weather/200904: Input/output error
wmr928eval (29.04.2009 10:12:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
logger (29.04.2009 10:12:10): data logger started.
logger (29.04.2009 10:12:11): connect station 0 (Vantage).
logger (29.04.2009 10:12:13): station 0 (Vantage), syncing.
logger (29.04.2009 10:12:13): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:12:13): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:12:13): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:12:15): failed making directory /data/weather/200904: Input/output error
logger (29.04.2009 10:12:40): data logger started.
logger (29.04.2009 10:12:42): connect station 0 (Vantage).
logger (29.04.2009 10:12:43): station 0 (Vantage), syncing.
logger (29.04.2009 10:12:43): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:12:43): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:12:43): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:12:48): failed making directory /data/weather/200904: Input/output error
wmr928eval (29.04.2009 10:13:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
logger (29.04.2009 10:13:10): data logger started.
logger (29.04.2009 10:13:11): connect station 0 (Vantage).
logger (29.04.2009 10:13:12): station 0 (Vantage), syncing.
logger (29.04.2009 10:13:12): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:13:12): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:13:12): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:13:18): failed making directory /data/weather/200904: Input/output error
logger (29.04.2009 10:13:40): data logger started.
logger (29.04.2009 10:13:41): connect station 0 (Vantage).
logger (29.04.2009 10:13:43): station 0 (Vantage), syncing.
logger (29.04.2009 10:13:48): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:13:48): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:13:48): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:13:53): failed making directory /data/weather/200904: Input/output error
wmr928eval (29.04.2009 10:14:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
logger (29.04.2009 10:14:10): data logger started.
logger (29.04.2009 10:14:11): connect station 0 (Vantage).
logger (29.04.2009 10:14:12): station 0 (Vantage), syncing.
logger (29.04.2009 10:14:12): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:14:12): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:14:12): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:14:13): failed making directory /data/weather/200904: Input/output error
logger (29.04.2009 10:14:40): data logger started.
logger (29.04.2009 10:14:41): connect station 0 (Vantage).
logger (29.04.2009 10:14:42): station 0 (Vantage), syncing.
logger (29.04.2009 10:14:42): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:14:42): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:14:42): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:14:48): failed making directory /data/weather/200904: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//hist-day1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//hist-hour1 for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//hist-last24h for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//hist-last60m for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//hist-last15m for writing: Input/output error: Input/output error
wmr928eval (29.04.2009 10:15:02): error while opening file /data/weather//seq-hour1 for writing: Input/output error: Input/output error
logger (29.04.2009 10:15:10): data logger started.
logger (29.04.2009 10:15:12): connect station 0 (Vantage).
logger (29.04.2009 10:15:13): station 0 (Vantage), syncing.
logger (29.04.2009 10:15:18): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:15:18): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:15:18): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:15:23): failed making directory /data/weather/200904: Input/output error
logger (29.04.2009 10:15:40): data logger started.
logger (29.04.2009 10:15:41): connect station 0 (Vantage).
logger (29.04.2009 10:15:42): station 0 (Vantage), syncing.
logger (29.04.2009 10:15:42): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:15:42): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:15:42): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:15:43): failed making directory /data/weather/200904: Input/output error
wmr928eval (29.04.2009 10:16:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
logger (29.04.2009 10:16:10): data logger started.
logger (29.04.2009 10:16:12): connect station 0 (Vantage).
logger (29.04.2009 10:16:13): station 0 (Vantage), syncing.
logger (29.04.2009 10:16:13): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:16:13): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:16:13): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:16:18): failed making directory /data/weather/200904: Input/output error
logger (29.04.2009 10:16:40): data logger started.
logger (29.04.2009 10:16:42): connect station 0 (Vantage).
logger (29.04.2009 10:16:43): station 0 (Vantage), syncing.
logger (29.04.2009 10:16:43): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:16:43): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:16:43): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:16:45): failed making directory /data/weather/200904: Input/output error
wmr928eval (29.04.2009 10:17:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
logger (29.04.2009 10:17:10): data logger started.
logger (29.04.2009 10:17:12): connect station 0 (Vantage).
logger (29.04.2009 10:17:13): station 0 (Vantage), syncing.
logger (29.04.2009 10:17:13): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:17:13): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:17:13): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:17:18): failed making directory /data/weather/200904: Input/output error
logger (29.04.2009 10:17:40): data logger started.
logger (29.04.2009 10:17:42): connect station 0 (Vantage).
logger (29.04.2009 10:17:43): station 0 (Vantage), syncing.
logger (29.04.2009 10:17:48): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.04.2009 10:17:48): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.04.2009 10:17:48): station 0 (Vantage), ready logging data.
logger (29.04.2009 10:17:53): failed making directory /data/weather/200904: Input/output error
sevenless
Post by sevenless »
That's really the gist of it right there -- there's a problem writing data to the disk. Odds are it's corrupted and gone into read-only mode and thus fails to record any configuration changes and can't create the monthly raw data folder, and because of this it shuts down logging.
Vyborg
Post by Vyborg »
Thanks! Now i have a doubt:
if i create a clone on a new memory stick is the problem preserved? i'm afraid to loose all data..:S
sevenless
Post by sevenless »
If any Meteohub system files are corrupted on your current stick, cloning it will copy the problems over to the new stick.
You should be able to back up your data off the old stick, either via rsync or the smb network share, then create a new USB stick image following the instructions given in the manual (via dd/diskwrite), and copy the archived weather data to your new stick. That's how I restored my data following a USB stick failure last year, and other than one corrupted entry in my data file that I needed to delete via the "inspect data" window in Meteohub, I had no problems.
