Can't find UV data from WMR200 **solved**
peterraf
Post by peterraf »
perhaps I am searching at the wrong places, but somehow I can't find the UV-Index values within Meteohub. The UV-Index is displayed on the WMR200 itself (and I had the timeline in the WeatherDisplay software before I switched to the Meteohub system on a NSLU2). Thanks in advance for any ideas ...
Regards, Peter Image
Re:Can't find UV data from WMR200
What version of Meteohub?
Any interesting info in "meteohub log"?
peterraf
Post by peterraf »
the last page of the meteohub log is:
wmr928eval (02.05.2009 08:58:00): no sensor found to match export name uv0
wmr928eval (02.05.2009 09:08:00): no sensor found to match export name uv0
wmr928eval (02.05.2009 09:18:00): no sensor found to match export name uv0
wmr928eval (02.05.2009 09:28:00): no sensor found to match export name uv0
wmr928eval (02.05.2009 09:38:00): no sensor found to match export name uv0
logger (02.05.2009 09:43:54): data logger started.
logger (02.05.2009 09:43:57): connect station 0 (WMR-200).
logger (02.05.2009 09:44:21): disconnect station 0 (WMR-200).
logger (02.05.2009 09:44:21): data logging stopped.
logger (02.05.2009 09:44:23): data logger started.
logger (02.05.2009 09:44:26): connect station 0 (WMR-200).
logger (02.05.2009 09:44:48): data logger started.
logger (02.05.2009 09:44:50): connect station 0 (WMR-200).
wmr928fulleval(02.05.2009 09:45:01): recomputation of weather data started.
logger (02.05.2009 09:45:08): data logger started.
logger (02.05.2009 09:45:17): connect station 0 (WMR-200).
logger (02.05.2009 09:45:44): data logger started.
logger (02.05.2009 09:45:50): connect station 0 (WMR-200).
logger (02.05.2009 09:47:43): station 0 (WMR-200), wrong checksum (b03a vs computed 0223) for sensor model d6 in byte sequence: d6 0d d3 10 32 08 02 05 09 07 0c 3a b0
logger (02.05.2009 09:52:02): station 0 (WMR-200), wrong checksum (2000 vs computed 0268) for sensor model d7 in byte sequence: d7 10 d3 10 37 08 02 05 09 05 0c 2c 10 02 00 20
logger (02.05.2009 10:01:09): station 0 (WMR-200), wrong checksum (0904 vs computed 02ff) for sensor model d4 in byte sequence: d4 16 03 09 02 05 09 00 00 d3 10 03 09 02 05 09 07 0c d7 10 04 09
logger (02.05.2009 10:01:09): station 0 (WMR-200), wrong checksum (0905 vs computed 0208) for sensor model d3 in byte sequence: d3 10 03 09 02 05 09 07 0c d7 10 04 09 02 05 09
logger (02.05.2009 10:09:39): station 0 (WMR-200), wrong checksum (d705 vs computed 0105) for sensor model d5 in byte sequence: d5 0a 0c 09 02 05 09 01 05 d7
logger (02.05.2009 10:10:35): station 0 (WMR-200), wrong checksum (0905 vs computed 0294) for sensor model d7 in byte sequence: d7 10 0d 09 02 05 09 02 8a d3 10 0d 09 02 05 09
logger (02.05.2009 10:17:19): station 0 (WMR-200), wrong checksum (0502 vs computed 01e5) for sensor model d9 in byte sequence: d9 08 d7 10 14 09 02 05
logger (02.05.2009 10:18:17): station 0 (WMR-200), wrong checksum (2000 vs computed 026d) for sensor model d7 in byte sequence: d7 10 d3 10 15 09 02 05 09 06 0c 21 40 02 00 20
logger (02.05.2009 10:20:37): station 0 (WMR-200), wrong checksum (2000 vs computed 02cb) for sensor model d7 in byte sequence: d7 10 d3 10 17 09 02 05 09 06 0c 2d 90 02 00 20
logger (02.05.2009 10:25:57): station 0 (WMR-200), wrong checksum (d7d1 vs computed 01d1) for sensor model d7 in byte sequence: d7 10 1c 09 02 05 09 01 90 00 24 00 00 00 d1 d7
logger (02.05.2009 10:28:54): station 0 (WMR-200), wrong checksum (d753 vs computed 0253) for sensor model d7 in byte sequence: d7 10 1f 09 02 05 09 00 d4 00 24 3c 00 00 53 d7
logger (02.05.2009 10:28:54): station 0 (WMR-200), wrong checksum (0009 vs computed 0000) for sensor model d4 in byte sequence: d7 10 1f 09 02 05 09 00 d4 00 24 3c 00 00 53 d7
logger (02.05.2009 10:32:17): station 0 (WMR-200), wrong checksum (0923 vs computed 047d) for sensor model d4 in byte sequence: d4 16 d7 10 23 09 02 05 09 00 d4 00 24 3c 00 00 57 02 d3 10 23 09
logger (02.05.2009 10:39:43): station 0 (WMR-200), wrong checksum (092a vs computed 0325) for sensor model d6 in byte sequence: d6 0d 2a 09 02 05 09 e5 33 d7 10 2a 09
wmr928fulleval(02.05.2009 10:42:51): recomputation of weather data finished: 1166083 records processed in 3463 seconds (336 records per second)
wmr928fulleval(02.05.2009 10:45:01): recomputation of weather data started.
logger (02.05.2009 10:45:48): station 0 (WMR-200), wrong checksum (003c vs computed 03de) for sensor model d3 in byte sequence: d3 10 d1 d7 10 30 09 02 05 09 00 d6 00 24 3c 00
hm, there is nothing that obviously comes into my mind. Could you open ports 22 and 7777 on your router and forward these to your Meteohub LAN IP? Please send WAN IP to info(at)meteohub.de, that would allow me to login and look myself.
Update from version 4.0 to 4.2d fixed the issue.
