Temp instead of Humidity are transferred with WD-Live
wfpost
Post by wfpost »
I tried to embed the humidity with one of my new sensors in WD-Live and saw now that not the values for humidity but the ones for temperature are displayed.
So, it looks like even if you select hum for one of the extra sensors in the WD-Live menue it is always the temp value that gets included in the clientraw file.
example on my website:
look for Gewächshaus and the hum instrument left of it with the wrong (temp) value.
http://www.myway.de/honsolgen/wdltemp.html
corresponding meteohub settings ...
Re:Temp instead of Humidity are transferred with WD-Live
Please make use of the clientraw data parser on this web site to check client raw data: http://www.tnetweather.com/wd-parser.php
What does it say for hum readings?
wfpost
Post by wfpost »
admin wrote:Please make use of the clientraw data parser on this web site to check client raw data: http://www.tnetweather.com/wd-parser.php
actually none values at all for the three humidity fields.
wfpost
Post by wfpost »
you can check yourself, if you want:
http://www.myway.de/honsolgen Image
Post by skyewright »
wfpost wrote:actually none values at all for the three humidity fields.
I don't use WDL, but that seems to make sense to me.
i.e. those the humidity values in clientraw are for sensors 1 2 & 3, but on the Meteohub page you have set up a humidity sensor in the sensor 4 position.
What if you put th4 in the Feuchte 3 position instead?
wfpost
Post by wfpost »
yep, it seems, the humidity values for HUM3 is transferred now.
My guess ist that there´s a WDL bug, because the WDL configurator does not give any instruments for humidity aside from the soil, outside, inside ones.
You can go for the extra instruments and then select HUM style, but then always the temp values are called from cleintraw. I need to check further what´s wrong here, but meteohub is not the culprit at this moment!
wfpost
Post by wfpost »
got it now to work ...
to show the Ext Hum 3 values from the clientraw.txt you need to select Extra Sensor 9 in WDL.XML :silly:
