Hello.
I have an problem with my WDL. I got the .xml from a site, and the moon rise/set never worked.
I see, that many of you have all the times inside. So can someone tell me, how to get this working?
My site can be seen on http://vreme.jausovec.com
And there is also another question about the Station's Altitude. This cyn be wieved on the adress:
http://www.wunderground.com/cgi-bin/fin ... ry=maribor down in "all weather statios" the first one is mine. Why is there no altitude shown? It is set on 280m.
Tnx for your answers and time :)
Regards, Uros
WDL sunrise/sunset, Station's Altitude
Re:WDL sunrise/sunset, Station's Altitude
afaik moon settings are not calculated by meteohub, therefore no figures for WDL. I recall someone had this posted in wishes ...urosh wrote:Hello.
And here is the answer from Julian.
Hi, the sun/moon information is included in the clientraw files with the rest of the data but I seem to recall there is a question mark over whether Meteohub can provide this information. You could check if it's being sent by using the clientrawparser at http://www.tnetweather.com/wd-parser.php or maybe email Boris.
The url in that config tag is for creating a link to a website on the sun/moon instrument within WDL.
Cheers
Julian
So Boris, will it be possible to include that or not? I find this as a great feature and would like to use it...
Regards, Uros
Cheers
Julian
Regards, Uros
- Junior Boarder
This feature is mentioned in the whishlist. I recall that Boris was trying to find suitable algorythm how to calculate those things.
I agree that this would be a good addition to the program. So perhaps it could be put on top of the priority list?
Depending on your familiarity with SSH, unix and html templates you can also check directly by looking aturosh wrote:You could check if it's being sent by using the clientrawparser at http://www.tnetweather.com/wd-parser.php or maybe email Boris.
\\home\\meteohub\\clientraw*.conf
Those are the "html template" files used to generate the uploaded clientraw*.txt files.
WDL sunrise/sunset
I have two Wx-stations at different locations, both north of the artic circle. The one running Weather-Display on a XP PC (http://www.nordbynes.info/Wdl/index.html) shows the correct sunrise/sunset (no sun).
The one running on Sheevaplug/Meteohub (http://www.nordbynes.info/andsvtn/Wx/huset.html) shows the same time for sunrise and sunset. Not too important maybe, but?
Ron
Ron
