RFreceiver prints out correct records for the connected sensors:
08.05.2009 23:21:37= 501A2D2077101370043090 TH1[30466] THGN122N,THGR122NX,THGR228N,THGR268 CH 2 addr:77 temp:13,1°C | 55,58°F hum:47 Normal bits=80
08.05.2009 23:22:03= 78CA2C53E6901720054EDBFFFF9559A6 TH4[58885] THGR328 CH ? = 53 counter:12 addr:E6 temp:17,9°C | 64,22°F hum:52 Normal bits=120
08.05.2009 23:22:10= 50EA4C103A501240C30A00 TEMP2[14849] THN132N,THWR288,AW131 CH 1 addr:3A temp:12,5°C | 54,5°F bits=80
08.05.2009 23:22:11= 501A2D40C9301800053A06 TH1[51460] THGN122N,THGR122NX,THGR228N,THGR268 CH 3 addr:C9 temp:18,3°C | 64,94°F hum:50 Normal bits=80
08.05.2009 23:22:12= 501A2D40C9301800053A06 TH1[51460] THGN122N,THGR122NX,THGR228N,THGR268 CH 3 addr:C9 temp:18,3°C | 64,94°F hum:50 Normal bits=80
But in case the VP2 is assigned the first ID for weather stations then the RFReceiver output reads like this:
09.05.2009 00:58:11= 000908140001640000020200FF0A000A noise or an unknown data packet received
09.05.2009 00:58:12= FF0AFF0AFF0AFF0AFF0AFFBE41DA0101 bits=127 from SLAVE
09.05.2009 00:58:12= C7C4 Buffer flushed due to timeout
09.05.2009 00:58:13= 4C4F4F14005E00B8759B02 bits=76
09.05.2009 00:58:13= 330E020101EB00FF noise or an unknown data packet received bits=51
09.05.2009 00:58:13= FFFFFFFFFFFFFFFFFFFFFFFFFFFF5EFF bits=127 from SLAVE
09.05.2009 00:58:13= FFFFFFFFFFFF00000000001B00095400 bits=127 from SLAVE
09.05.2009 00:58:14= 00A300CF0200006200E802FFFFFFFFFF noise or an unknown data packet received
09.05.2009 00:58:14= FFFF0000000000000000000000000000 bits=127 from SLAVE
09.05.2009 00:58:14= 00000001F70208012202F9070A0DC720 noise or an unknown data packet received
09.05.2009 00:58:15= 4C4F4F14005E00B8759B02 bits=76
09.05.2009 00:58:15= 330E020101EB00FF noise or an unknown data packet received bits=51
09.05.2009 00:58:15= FFFFFFFFFFFFFFFFFFFFFFFFFFFF5EFF bits=127 from SLAVE
09.05.2009 00:58:15= FFFFFFFFFFFF00000000001B00095400 bits=127 from SLAVE
09.05.2009 00:58:16= 00A300CF0200006200E802FFFFFFFFFF noise or an unknown data packet received
09.05.2009 00:58:16= FFFF0000000000000000000000000000 bits=127 from SLAVE
09.05.2009 00:58:16= 00000001F70208012202F9070A0DC720 noise or an unknown data packet received
Could it be that the 1:1 copy feature on port 5500 is still considering an one station operating mode and does only transmit the USB-data from the 1st weather station to port 5500.
Then it would be pretty much clear that RFreceiver isn´t capable of reading the VP2 data?
