meteohub webserver does not work
zfreitas
Post by zfreitas »
Can someone help me on this.
After installing v4.2d (veryfied only few days after), I was unable to access the meteohub webserver.
There are ather things that also dont work.
The graphs defines by me on meteohub stop at 15 May and data to wdlive stopped last night. Data sended to wundergroung is working fine.
I switch off the meteohub device, swap the usb ports and start again. Now the wdlive data is running ok, but I still cannot access the meteohub´s webserver neither the graphics are working.
To access my meteohub you should type http:\\\\xxxxxxxxxxxxx and the system should prompt for a username and password.
You can also try to browse data at: http:\\\\xxxxxxxxxxxx\\myweb\\uploads
Can Boris or someone else help me?
Re:meteohub webserver does not work
I stripped your dyndns data, as that might provoke some misuse. please send me an email "info(at)meteohub.de" to setup a way for me to login.
