"illegal data record"
maxd
Post by maxd »
For the last week or so I see the following errormessages on my meteohub Version 4.2:
wmr928eval (03.06.2009 04:54:20): illegal data record in line 305732 while reading from file /data/weather/200903/raw: 20090310190009 wind0 38
wmr928eval (03.06.2009 04:54:20): illegal data record in line 305733 while reading from file /data/weather/200903/raw: 200903101)0011 wind0 41 31 22 0021
wmr928eval (03.06.2009 04:54:20): illegal data record in line 305738 while reading from file /data/weather/200903/raw: 2009031019001 wind0 95 76 22 -001
Should I just delete the offending lines in /data/weather/200903/raw?
--md
sevenless
Re:"illegal data record"
Post by sevenless »
You can try doing that, but also be aware this could be a sign of impending USB stick failure, so make sure you've got your data, graph definitions and settings backed up somewhere.
yes looks like USB stick trouble.
You can try to automatically let Meteohub purge the bad lines.
1) stop data logging
2) goto "inspect data" page
3) select troubled month (2009-03)
4) press "cleanup data"
5) wait till finished
6) start data logging again
7) start recomputation and watch meteohub log file
