Boris,
actual_sol0_evotranspiration_mm is present and has a value associated with it but it is not getting to clientrawextra byte 532 or 533.
What am I doing wrong, any suggestions? I can check the clientrawextra file on the TNET web site and when I parse the file neither byte has a value in it?
ET and Clientrawextra
Re:ET and Clientrawextra
Just for info, it would be good if you can make the VP2Plus ET populate byte 532 as WDL does not use byte 533. Just had it confirmed by Julian, see below.
"Yes WDL uses 532. I guess 533 was made available for some reason in the past but I couldn't tell you why. Brian may be able to if he sees this."
Mike
Mike
So the value of actual_sol0_evotranspiration_mm needs to be converted to mm and put in clientrawextra file byte 532 then WDL will report ET from the VP2 Plus.
regards
Mike
regards
Mike
Boris,
Have just upgraded to 4.3f but byte 532 of the clientrawextra.txt file is still not showing the VP ET value although actual_sol0_evotranspiration_mm is? Can you fix please.
regards
Mike
regards
Mike
Re:ET and Clientrawextra - NOW FIXED
Thanks Boris, just installed V4.4 and this now works fine... Mike
