Question about the swap file
dcspicer
Post by dcspicer »
I recently noticed that under the information page under storage there is a line there for swap file. It reads Swap: -1MB of -1MB used (100%). Meteohub is running under VM. Why is it showing this and is there concern?
sevenless
Re:Question about the swap file
Post by sevenless »
I'm not running Meteohub under VM, but I've run other applications in VM environments and seen that for them as well. I suspect it either has something to do with the settings you use when initializing the VM environment, or it might simply be a limitation in the /proc system of VM installations that prevents it from querying data on the host, causing a null value to be reported.
