Hello
I use in connection with meteohub Weather Display Live. I have a few errors by radio interference. These are now in my saved records contain WDL. Where can I delete the wrong record?
Wölkchen
Delete wrong records for WDL??
Re:Delete wrong records for WDL??
Have a look at raw data files. Format is explained in the manual.
Hello Boris
your description says the data will be written: 20071101145756 rain0 0 0 2764
In my system the data is written: rain0 0 0 239420090615020417
Is it true they split:
rain0 = Sensor
0 0 = current value
2394 = rain rate (239.4)
2009 = Year
06 = month
15 = day
02 = hour
04 = minute
17 = seconds
My record leaves no other explanation for.
If I now Highs in the recording delete / wants to improve, I must improve all the values?
Created the system the hist files from the raw file?
Thanks for your help
Wölkchen
rain0 = Sensor
0 0 = current value
2009 = Year
06 = month
15 = day
02 = hour
04 = minute
17 = seconds
Wölkchen
that looks like a storage error to me. Do you still have these kinds of logged raw data?
Hello Boris
I like you in a personal message that is my Sysetm crashed.
After the new installation are the errors in the rain rate, but recovered again.
I have eliminated all sources of interference. Now can I get a radio signal interference 100% exclusively. The reason being?
My records will now see this:
rain0 0 0 2508
20090626074726 th0 206 71 0152
20090626074726 thb0 231 60 0149 9801 -1 10095
20090626074726
Is there a bug in the programming for the
WH1080 be?
Greeting Wölkchen
rain0 0 0 2508
20090626074726
WH1080 be?
Greeting Wölkchen
can you give me access to your Meteohub? please email WAN IP to info(at)meteohub.de and forward ports 22 and 7777 on your router to your Meteohub's LAN IP.
Hallo Boris
Die erste falsche Messung der Regenrate erfolgte am 25.06.2009 um 11:49.
Ich habe mal nachgedacht ob ich zur dieser Uhrzeit etwas am Sysetm geändert habe. Ich bin mir zu 100% sicher das ich exact um diese Uhrzeit die Erfassung für den Datenexport nach WSWIN gestartet habe.:dry: Grund: Kurz nach dem Start des Exports habe ich die ausgelagerte CSV-Datei kopiert und auf meinem Rechner gesichert.
Vieleicht ist das ein Hinweis, oder andere Benutzer können das gleiche berichten.
Gruß Wölkchen
Hello Boris
The first erroneous measurement of rain rate was made on 25.06.2009 at 11:49.
I once thought if I was on something at this time Sysetm changed. I am 100% sure that I order these exact time for the collection of the data export after WSWIN had started. Reason: Shortly after the start exporting, I have outsourced the CSV file is copied and saved on my computer.
Perhaps this is an indication or other user can use the same report.
Wölkchen
Gruß Wölkchen
Hello Boris
Wölkchen
