Connection refused
HeinrichH
Connection refused
Post by HeinrichH »
Everything was worked well but the datalogging stopped.
See attached file, the connection is refused and I don't know how to start the logging again.
I restarted the PC and restarted VMware several times but no succes. The version is the latest, 4.3f
Anybody knows how to resolve this problem? Image
Checking the remote....
HeinrichH
Re:Connection refused
Post by HeinrichH »
Anybody an idea??
The problem is still there!
Data logging can be started on "Maintenance" page. Is "meteohub log" giving some information what is going wrong. I guess low level connection to your station has dropped. Are USB ports correctly assigned to VMware guest machine.
HeinrichH
Post by HeinrichH »
When I push the start button nothing is happened.
I only use network stations, station 1 is a Davis VP Pro and station 2 is a RFXcom receiver, both are connected trough TCP/IP. The network adapter is "bridged" and connected to VMware player, I don't use USB.
havasurose
Post by havasurose »
I just installed V 4.3 today. I was able to get all the sensors recognized and then I received the same MSG "error connect socket 127.0.0.1:555 : Connection refused". I am running an Oregon WRM968. I have to reboot and the sensors will work, as soon as you refresh and save the error appears.
Any thoughts would be appreciated.
thanks
HeinrichH
Post by HeinrichH »
I don't know what happened, I did not do anything but the logging process is started again and the file size is normal again.
When the error occured the storage for data use was about 80% of 2903 MB, now back to 11%
please update to 4.4 with "auto" update.
HeinrichH
Post by HeinrichH »
With 4.4 it's running well but I still don't know what happened, I found one entry in the meteohub log of "to many files open" but the file system seems to be normal now
