Graph Upload limited to 30? **solved**
cbhiii
Post by cbhiii »
I have started to use the Graph Upload for my graphs to FTP on my site.
Can I increase the limit of 30 CRON jobs?
Re:Graph Upload limited to 30?
My Meteohub generates and uploads 46 graphs every 5 minutes. Where did you find a formal limit for this?
does cron throw an error? never seen this
my graph generations don't start all exactly at the same time. As there are some graphs for the week or month this does not need to computed every 5 minutes because nobody will see a change.
cbhiii
Post by cbhiii »
After 30 graphs or cron jobs listed in the graph upload section the webpage does not respond. You have to delete some before you can save the page.
as the params are transfered via http-get on the url this might get too long. Could you please send me a paste of your url when being at the limit after pressing \"save\". This limit can depend on browser limits and other factors.
I will look if I can switch to http-post for avoiding this limit (if my theory is right).
cbhiii
Post by cbhiii »
Here is my URL for Graph Upload. I can't click save after this many graph uploads.
... too long line, removed by admin ....
cbhiii
Post by cbhiii »
I modified some of my graph uploads with more text in the 'cron schedule' and I had to remove more graphs to get it to save. So, yes, it appears to be an issue with too much text in the URL.
switching to http-post does do the trick. will be in the 2.1a update.
cbhiii
Post by cbhiii »
Thanks Boris. That will help a lot. Didn't want to have to start editing my crontab. :o
