using DD
styrmand
using DD
Post by styrmand »
I have unpacked a brand new NSL2. I had prepared to install Meteohub on it.
I have made the first small usb-stik with the newest firmware upgrade.
I have a 4 GB stick, and downloaded meteohub-v4.3-4GB.rar, unpacked meteohub-v4.3-4GB.dd
Then according to the documentation i shal use dd to copy the file to the usb-stick?
When i Google documentation for dd i get replies i dont understand.
Is there a command line sample in here somwhere?
wfpost
Re:using DD
Post by wfpost »
dd is a linux command for low level copying
http://en.wikipedia.org/wiki/Dd_%28Unix%29
If you do not have a linux computer you could use the Windows dd version from the downloads section here at meteohub:
dd for Windows (Version 0.5)hot!
ENGLISH:
this free software, published under GPL, is a port of the Linux dd command to Windows. Details about thr software and its license cab be found here:
Remark: This version does not work on Microsoft Vista.
Download
be careful: if you entering a wrong target disk, i.e. your boot partitions on your PC, dd will erase them.
styrmand
Re:using DD
Post by styrmand »
I am running Linux but im not familiar with the dd command at all.
It the parameters, and options that I'm uncertain about. Should i use special blocksize or other options or is
dd if=/home/ole/file.dd of=/media/KINGSTON
sufficient?
Maybe i just have to give it a try? :dry:
styrmand
Re:using DD
Post by styrmand »
Seems like this did it:
sudo dd if=meteohub-v4.3-4GB.dd of=/dev/sdb1
(Running ubuntu 9.04)
thx
