Hi !
Where can i find the file that is created for Weather Display (WD). I´m using WD 10.37O build2 and i dont get any rain from Meteohub to wd (Yes rain Sensor is marked)
The export to WDL does work !
I want to check the log file (WHICH ONE??) to check if there are raindatas inside !
wfg
Martin
No Rain from Meteohub in Weather Display ?!
Re:No Rain from Meteohub in Weather Display ?!
If you have WD set to use the "logging protocol" method of collecting data from Meteohub then the "WD Data Export" page in the Meteohub web interface is not at all relevant.martin150 wrote:Where can i find the file that is created for Weather Display (WD). I´m using WD 10.37O build2 and i dont get any rain from Meteohub to wd (Yes rain Sensor is marked)
When reading data via the "logging protocol" WD only reads rain from the sensor assigned as rain0.
This cannot be re-configured at the WD end of things.
If you are not using rain0 at the Meteohub end the most straight forward thing to do is to reassign the sensor ID in Meteohub.
There is a eloborate alternative involving setting up a web server proxy to sit between Meteohub and WD and 'tweak' IDs on-the-fly using a custom script, but simply reassigning the sensor is what most people are likely to opt for.
I hope that helps.
David
Hi ! The little things make the life complicated;) I´m searching now for 3 days, but didnt find the mistake. Always did look at the "sensors" page.skyewright wrote:If you have WD set to use the "logging protocol" method of collecting data from Meteohub then the "WD Data Export" page in the Meteohub web interface is not at all relevant.martin150 wrote:Where can i find the file that is created for Weather Display (WD). I´m using WD 10.37O build2 and i dont get any rain from Meteohub to wd (Yes rain Sensor is marked)
I hope that helps.
David
Now i did found out my rain sensor has id rain1 and not rain0 :unsure:
I did change now to rain0 and hope my problem is gone !
TNX A LOT !!!
Martin
Now, after first rain quit sure that the problem is gone.:) Rainfall is displayed in WDmartin150 wrote:Hi ! The little things make the life complicated;) I´m searching now for 3 days, but didnt find the mistake. Always did look at the "sensors" page.skyewright wrote:If you have WD set to use the "logging protocol" method of collecting data from Meteohub then the "WD Data Export" page in the Meteohub web interface is not at all relevant.martin150 wrote:Where can i find the file that is created for Weather Display (WD). I´m using WD 10.37O build2 and i dont get any rain from Meteohub to wd (Yes rain Sensor is marked)
I hope that helps.
David
TNX A LOT !!!
Martin
tnx agn
Martin
