Floating point exception on eBox-3300 running v4.4
cbhiii
Post by cbhiii »
I woke up this morning to a dead Meteohub.
Just after 6:30am local time the problem started. This is the second time that my unit started having problems at about 6:30am which happened a few days ago. The only fix was to reboot my hardware.
Today before I rebooted I connected to the terminal port of the ebox-3300 to talk to the software. I kept getting "Floating point exception" on every program I was trying to run. I couldn't run 'ps' to check processes. I couldn't run 'top' to see them either. I kept getting "Floating point exception" on most everything I tried.
I was able to run 'cat' on file logs and such, but could not run the copy command. It seems that meteohub was running kind of because I was getting ftp error connection emails saying that it couldn't connect. I could connect to meteohub over LAN either.
Has anyone else seen this? Do you have any ideas as to the cause?
Thank you
