Tried update to V4.4 but since then I can no longer connect to meteohub via web interface.
have tried turning NSLU 2 off and on again and all lights come on at sometime and bleeps are heard before top two lights remain solid green.
Please has anyone any suggestions as to what has gone wrong
Web connection problem
Re:Web connection problem
It could be that you have got a new ip address because of DHCP and you are trying with the wrong address.
You know that all the bleeps tells you the ip address of the NSLU2? And if I remember correctly ten bleeps equals 0.
southfield
- Fresh Boarder
IP scan shows 2 ip adresses available but neither will connect.
Am trying to build a new memory stick at the moment to see if this is the problem and am waiting for it being transfered from one stick to the other using the nslu2
Will let you know how I get along
southfield
- Fresh Boarder
Have got meteohub working by copying new version onto a new memory stick
However I have had to reset all the options just like a new install and version has returned to evaluation version
Will need to contact Boris to find out how to relicence this version.
