4.4a update - HTML template problem
gpfoto
Post by gpfoto »
I've just updated from 4.4 to 4.4a (x86) and the html template I use is created as a cero byte file.
I've tried some other templates, but it does not work also.
I've seen that with v4.4a MeteoHub creates a folder "\\uploads\\uploads" and is here where it creates the files to upload via FTP. Reather than on the folder "\\uploads" like on v4.4.
Any ideas?
Thank you!
Re:4.4a update - HTML template problem
Good observation. I checked the code and there was a bug regarding generation of html templates.
Please install 4.4a again (possible via auto update) to get the corrected version. I did not give that small bug fix a unique version number.
Please press "save" on "Graph Uploads" page to make changes effective.
gpfoto
Post by gpfoto »
Ok. I'll try it tomorrow. By now, to solve it, I've downgraded to v4.4 and also need to "save" on "Graph Uploads".
I'll let you know.
Thank you
gpfoto
Post by gpfoto »
Updated now to v4.4a, with the HTML templates working fine.
Thank you for your fast correction.
gpfoto
