No Timestamp for Min Max Data ** solved **
patonnet74
Post by patonnet74 »
When generating HTML using \"http://..../meteohtml.cgi?file=test-template\" there doesn't appear to be any values for a timestamp for any of the minimum or maximum values.
The documentation shows values like \"day1_th0_tempmax_time\"
should be available, but when you run
\"http://..../meteograph.cgi?text=all\"
Those fields do not show.
There are no timestamps for any of the minimum/maximum data.
Alan
Re:No Timestamp for Min Max Data
If you are using versions 2.0d or 2.1 the data should be there. which version do you have?
patonnet74
Yep, sorry, I hadn't realised I was only on v2.0
All working with an update. Thanks!
mvpel
Post by mvpel »
Ambient Weather is still shipping v2.0 - I had to upgrade the unit which arrived on Wednesday.
