Error file open /home/meteohub/meteohub.conf
rovinj
Post by rovinj »
suddenly I got error 'Error file open /home/meteohub/meteohub.conf' on my NSLU2.
SMB shares also is stopped so I can not move my date to a new USB stick. Can anyone help with some advice?
Nimbus43
Re:Error file open /home/meteohub/meteohub.conf
Post by Nimbus43 »
same problem here.
Boris: No hint, no solution?
Thanks for your help.
Only explanation is a faulty file system. Are you using NSLU2 with USB stick?
Login via ssh might shed some more light on this. Is "/home/meteohub/meteohub.conf" accessible from the command shell? What does "ls -la /home/meteohub" tell you? Can you make a copy of the file? Does "dmesg" report errors on "/dev/sda"? has "/dev/sda1/" being remounted in read-only mode because of data corruption?
