SheevaPlug broken?
skogvaktare
SheevaPlug broken?
Post by skogvaktare »
Hi everybody!
Today FedEx arrived with my new sheevaPlug.
After open the package, I heard a loud "klick"-noise from the inner side of the device.
So I just want to ask those of you, who already had the plug, if this is ok, before starting installing the meteohub.
When I connect the power plug, the two LEDs begin to blink, but these noise sounds a bit strange and not very healthy.
I would be glad for some answers.
Christian
Re:SheevaPlug broken?
There is no rattle when moving my SheevaPlug.
You can easily open it by removing the 4 rubber feet (can be inserted again later on) and by removing the 4 screws behind that.
Having a look inside should tell you the truth, if there is something wrong/broken/fallen apart.
skogvaktare
Hi!
Thanks a lot. I already did it.
There was just an thin aluminium coverage in the upper part, which was fallen out of it´s position. Maybe because of the handling while shipping.
I fixed it an today i will get these specific sd card.
Unfurtunatly I have no linux pc, so I will try to install it via unix terminal on my mac. I hope that will succeed.
Have a nice weekend,
Christian
Dhoom
Re: SheevaPlug broken?
Post by Dhoom »
THANKS thats a BIG help!
:D :D
Are you worried about ccnp practice test You can get our 100% COMPTIA certification practice test Alabama State University contains all those materials you want to Columbia University paced test engine to help you pass Northwestern University
