Mandriva Linux vmware Wrong checksum
Manuel
Post by Manuel »
Hallo,
Ich habe vor kurzem ein WRM 200, bin ich mit vorinstalliertem Mandriva Linux, Französisch Ich bin, ich hoffe, zu erklären.
Sie rieten mir Meteohub ich die VMware Image zu meinem WRM 200 erkannt wird gut, aber kein Graph tun, hier werden die Protokolle.
Sep 7 16:40:47 meteohub kernel: drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
Sep 7 16:40:47 meteohub kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
Sep 7 16:40:47 meteohub kernel: usbcore: registered new interface driver ftdi_sio
Sep 7 16:40:47 meteohub kernel: drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
Sep 7 16:40:47 meteohub kernel: ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
Sep 7 16:40:46 meteohub kernel: eth0: no IPv6 routers present
expr: division by zero
logger (07.09.2009 16:52:14): unexpected 0 bytes delivered from weather station 0 (WMR-200)
logger (07.09.2009 16:52:15): data logger started.
logger (07.09.2009 16:52:16): connect station 0 (WMR-200 via USB HID).
wmr928fulleval(07.09.2009 16:55:01): recomputation of weather data started.
wmr928fulleval(07.09.2009 16:55:02): recomputation of weather data finished: 3324 records processed in 1 seconds (3324 records per second)
logger (07.09.2009 17:00:54): station 0 (WMR-200), wrong checksum (0909 vs computed 02cc) for sensor model d3 in byte sequence: d3 10 10 28 78 00 50 0e 02 b7 01 11 07 09 09 09
logger (07.09.2009 17:00:59): station 0 (WMR-200), wrong checksum (5000 vs computed 02a1) for sensor model d3 in byte sequence: d3 10 d7 10 01 11 07 09 09 00 0b 01 28 78 00 50
logger (07.09.2009 17:05:18): station 0 (WMR-200), wrong checksum (0a09 vs computed 02d4) for sensor model d3 in byte sequence: d3 10 10 28 78 00 50 12 02 b7 05 11 07 09 09 0a
logger (07.09.2009 17:05:19): station 0 (WMR-200), wrong checksum (2000 vs computed 02e0) for sensor model d7 in byte sequence: d7 10 d3 10 05 11 07 09 09 07 0c 13 c0 01 00 20
logger (07.09.2009 17:14:08): station 0 (WMR-200), wrong checksum (0909 vs computed 02e6) for sensor model d3 in byte sequence: d3 10 10 01 28 78 00 50 1c b7 0e 11 07 09 09 09
logger (07.09.2009 17:14:09): station 0 (WMR-200), wrong checksum (4a00 vs computed 025a) for sensor model d7 in byte sequence: d7 10 d4 16 0e 11 07 09 09 07 00 04 00 46 00 4a
Wie dieses Problem zu lösen, ich danke Ihnen für ihre Hilfe.
Guten Tag
In english
I recently a WRM 200, I am running Mandriva Linux, I am French, I hope to explain.
They advised my météohub I download the vmware image to my WRM 200 is well recognized, but no graph do this, here are the logs.
How to solve this problem, thank you for helping me.
Good day
en Français
Bonjour,
j'ai depuis peu une WRM 200, je suis sous Mandriva Linux, je suis Français, j'espère bien m'expliquer.
On ma conseillé météohub, j'ai télécharger l'image pour vmware, ma WRM 200 est bien reconnu, mais aucun graphe ne ce fait, voici les logs.
Comment résoudre ce problème, merci de m'aidé.
Bonne journée
