Hi :)
Since I updated to version 4.4d temperature data from WD is a few times a day not in tune with the correct temperature from meteohub. Like, it's 24,0ºC right now and falling and WD is still at 24,3ºC for several minutes, until it eventually updates to the correct temperature.
I checked http://meteohub/meteolog.cgi?mode=data reloading the page frequently and I can confirm that sometimes the temperature sensor doesn't show for several minutes and most of the time it shows wind data.
WD temperature is not updated
Re:WD temperature is not updated
That happens quite often if you (or WD) only look at sensors using "the most recent sensor", but that should not be a problem WD should also be doing "all sensors in the last minute" readaings once a minute. You can simulate that with a call like:fil wrote:I checked http://meteohub/meteolog.cgi?mode=data reloading the page frequently and I can confirm that sometimes the temperature sensor doesn't show for several minutes and most of the time it shows wind data.
http://meteohub/meteolog.cgi?mode=data& ... 0911080100
N.B. The times in such a URL always in GMT.
Provided the temperature is appearing in the "all sensors in the last minute", then WD ought to be seeing it.
Maybe you could check that too?
David
Thanks for the reply.
Yes with that URL all sensors show up. So it could be a WD problem?
This is how it looks in WD graph:
