I get this quite often with my brand new WMR100 running on a Meteohub 4.5. Data from some sensors are not shown on Meteohub. (e.g. the sensor on WMR100). I have replaced all batteries with new ones, no help.
Any good ideas?
meteohub log:
logger (14.09.2009 21:34:06): unexpected 0 bytes delivered from weather station 0 (WMR-100)
logger (14.09.2009 21:34:06): disconnect station 0 (WMR-100).
logger (14.09.2009 21:34:07): data logger started.
logger (14.09.2009 21:34:08): connect station 0 (WMR-100 via USB HID).
wmr928fulleval(14.09.2009 21:35:02): recomputation of weather data started.
wmr928fulleval(14.09.2009 21:35:03): recomputation of weather data finished: 463 records processed in 1 seconds (463 records per second)
logger (14.09.2009 21:48:38): unexpected 0 bytes delivered from weather station 0 (WMR-100)
logger (14.09.2009 21:48:38): disconnect station 0 (WMR-100).
logger (14.09.2009 21:48:40): data logger started.
logger (14.09.2009 21:48:40): connect station 0 (WMR-100 via USB HID).
logger (14.09.2009 21:48:40): connect station 1 (System Data via ).
logger (14.09.2009 21:48:55): unexpected 0 bytes delivered from weather station 0 (WMR-100)
logger (14.09.2009 21:48:55): disconnect station 0 (WMR-100).
logger (14.09.2009 21:48:56): data logger started.
logger (14.09.2009 21:48:56): connect station 0 (WMR-100 via USB HID).
logger (14.09.2009 21:48:56): connect station 1 (System Data via Plug-in).
logger (14.09.2009 21:55:42): unexpected 0 bytes delivered from weather station 0 (WMR-100)
logger (14.09.2009 21:55:42): disconnect station 0 (WMR-100).
logger (14.09.2009 21:55:43): data logger started.
logger (14.09.2009 21:55:44): connect station 0 (WMR-100 via USB HID).
logger (14.09.2009 21:55:44): connect station 1 (System Data via Plug-in).
wmr928fulleval(14.09.2009 22:00:01): recomputation of weather data started.
wmr928fulleval(14.09.2009 22:00:02): recomputation of weather data finished: 585 records processed in 1 seconds (585 records per second)
logger (14.09.2009 22:01:38): parent process received termination signal (15).
logger (14.09.2009 22:01:38): child process received termination signal (15).
logger (14.09.2009 22:01:40): disconnect station 0 (WMR-100).
logger (14.09.2009 22:01:40): disconnect station 1 (System Data).
logger (14.09.2009 22:01:40): data logging stopped.
logger (14.09.2009 22:02:36): data logger started.
logger (14.09.2009 22:02:36): connect station 0 (WMR-100 via USB HID).
logger (14.09.2009 22:02:36): connect station 1 (System Data via Plug-in).
logger (14.09.2009 23:10:56): unexpected 0 bytes delivered from weather station 0 (WMR-100)
logger (14.09.2009 23:10:56): disconnect station 0 (WMR-100).
logger (14.09.2009 23:10:57): data logger started.
logger (14.09.2009 23:10:57): connect station 0 (WMR-100 via USB HID).
logger (14.09.2009 23:10:57): connect station 1 (System Data via Plug-in).
wmr928fulleval(14.09.2009 23:15:01): recomputation of weather data started.
wmr928fulleval(14.09.2009 23:15:03): recomputation of weather data finished: 1078 records processed in 2 seconds (539 records per second)
logger (14.09.2009 23:36:20): unexpected 0 bytes delivered from weather station 0 (WMR-100)
logger (14.09.2009 23:36:20): disconnect station 0 (WMR-100).
logger (14.09.2009 23:36:21): data logger started.
logger (14.09.2009 23:36:22): connect station 0 (WMR-100 via USB HID).
logger (14.09.2009 23:36:22): connect station 1 (System Data via Plug-in).
wmr928fulleval(14.09.2009 23:40:01): recomputation of weather data started.
wmr928fulleval(14.09.2009 23:40:03): recomputation of weather data finished: 1249 records processed in 2 seconds (624 records per second)
