Sensor Data for 'sol0' sensor ** solved **
cbhiii
Post by cbhiii »
Is there a name for the sensor data from my solar sensor?
I couldn't find it listed in section 4.4. I did try actual_sol0_index just in case but it did not work. Is it there and just not listed? Thanks.
Re:Sensor Data for 'sol0' sensor
with \"http://your-meteohub-ip/meteograph.cgi?text=all\" you get all variables available for your station and sensor setup.
\"sol\" sensors are only avail for the vantage, the data is avail via variable \"actual_sol0_radiation\".
cbhiii
Re:Sensor Data for 'sol0' sensor ** solved **
Post by cbhiii »
Thanks. It works great!
