Is the RTGR328N supported?
This is intended for discussion and information about the rfxcom receiver module
Headworx
Post by Headworx »
This sensor has an atomic clock receiver... It is not on the official list... but may be it is supported (via RFXcom)? I've found a cheap source of them (~EUR 8) but would not want to get something that does not work....
Cheers,
Headworx
Re:Is the RTGR328N supported?
THGR328N is supported, if the RTGR sends the same signals? hard to say... I would guess 80% that it does...
Headworx
Post by Headworx »
I *think* it also sends current time... Anyway, I'll order one to see...
HeinrichH
Post by HeinrichH »
Headworx wrote:I *think* it also sends current time... Anyway, I'll order one to see...
How are you doing with this sensor? All ready working?
Checking the remote....
Headworx
Post by Headworx »
Yest they are working very well. The ones I have have broken clocks, that was the reason they were so cheap... I have 12 of them... MH just takes the temperature and humidity, discards the clock... So it is fine for me...
Cheers,
Headworx
HeinrichH
Post by HeinrichH »
12? that's a lot.
I'm more interesting in the clock function because I have two stations running in different time zones and I was wandering how Meteohub handle the clock.
Headworx
Post by Headworx »
Nope... MH uses it's own clock.
I think the better idea is to set up ntp clock synchronization at the system level...
    # ntpdate pool.ntp.org
    # hwclock --systohc
HTH,
Headworx
HeinrichH
Post by HeinrichH »
Yes, I know and I'm using the time sync on both locations. But it can be easy to have a time sensor field in the database.
