Vantage Vue doesn't seem to work with Meteohub 4.5a
mfarmwald
Post by mfarmwald »
It very occasionally can get data, but stops quickly. Same USB-serial works with Vantage Pro2, so I'm pretty sure the problem is with Vantage Vue only.
Here's some log entries:
logger (29.09.2009 16:45:17): station 0 (Vantage), repeated init failure, preparing for restart.
logger (29.09.2009 16:45:17): data logger started.
logger (29.09.2009 16:45:21): connect station 0 (Vantage via USB serial).
logger (29.09.2009 16:45:22): no signal from station 0 (Vantage) for 150 seconds, station to be restarted.
logger (29.09.2009 16:45:22): disconnect station 0 (Vantage).
logger (29.09.2009 16:45:27): connect station 0 (Vantage via USB serial).
logger (29.09.2009 16:45:32): no signal from station 0 (Vantage) for 150 seconds, station to be restarted.
logger (29.09.2009 16:45:32): disconnect station 0 (Vantage).
Re:Vantage Vue doesn't seem to work with Meteohub 4.5a
yep, please give 4.5b a try.
spoetnik
Post by spoetnik »
Work fine with MeteoHub: Version 4.5c
