Graphing wind direction
hasteiner
Post by hasteiner »
I am using a line graph to plot wind speed and direction. Unfortunately, most of my wind comes from the North, plus or minus a few degrees.
This results in a very ugly graph as the values jump between 350 and 10 on almost every report.
I am thinking that it would be good to be able to subtract 180 from the direction value being plotted and having a graph that goes between -180 and 180 degrees instead, which will result in a relatively flat direction line across the middle of the graph.
Does anyone know an easy way to manipulate the data in the graph to achieve this? I cannot calibrate it in the settings section of meteohub or everything is South instead of North.
Has anyone done something different with their direction graphs?
Re:Graphing wind direction
Post by skyewright »
hasteiner wrote:Has anyone done something different with their direction graphs?
I plot direction using "Points" as the "Display Type".
I find that approach works fine for me. Maybe you'll like it too?
Vetinari
Post by Vetinari »
skyewright wrote: I plot direction using "Points" as the "Display Type".
I did it the same way, except that I changed the °-sign to the text-mode. So you have a direct link with the points to the wind-direction.
hasteiner
Post by hasteiner »
Sometimes the answer is so obvious, and still I need to be told :unsure: .
The points look much better, thank you very much.
