Graphing wind direction
Posted: Wed Sep 30, 2009 3:07 am
I am using a line graph to plot wind speed and direction. Unfortunately, most of my wind comes from the North, plus or minus a few degrees.
This results in a very ugly graph as the values jump between 350 and 10 on almost every report.
I am thinking that it would be good to be able to subtract 180 from the direction value being plotted and having a graph that goes between -180 and 180 degrees instead, which will result in a relatively flat direction line across the middle of the graph.
Does anyone know an easy way to manipulate the data in the graph to achieve this? I cannot calibrate it in the settings section of meteohub or everything is South instead of North.
Has anyone done something different with their direction graphs?
