WDL rain rate records are 60x too high
markhiseman
Post by markhiseman »
Dear Boris,
Under the Records button on my website, the maximum rain rate is 60x too high. E.g. it shows an all time record of 444 mm/hr instead of the actual 7.4 mm/hr. The same problem affects all time, yearly and monthly records.
Real time operation is fine, and it will display the correct cumulative totals and the correct mm/hr rate on the live display when it is raining.
The WDL parser at http://www.tnetweather.com/wd-parser.php shows that my clientrawextra file (attached) contains 7.4mm in field #331 (record all time rain rate). I checked with Softvark, at the WDL bug tracker website, and he tells me that all such fields should be in mm/min not mm/hr.
Is there a Meteohub setting I've missed, or can this be fixed?
Many thanks for a great product, and for your help on this.
Mark. [file name=clientrawextra.txt size=2362]http://www.meteohub.de/joomla/images/fb ... wextra.txt[/file]
Re:WDL rain rate records are 60x too high
Thanks for getting that details from Julian.
I will change this with next update.
markhiseman
Fixed and working in v4.5d. Thanks!
Mark.
