The forecast text in the variable \"actual_thb0_fc_text\" is cut off when used on a webpage.
For example the text should be \"Increasing clouds and cooler temps\", but only the word \"Increasing\" is displayed on the webpage.
Forecast variable cut off on webpage ** solved **
Re:Forecast variable cut off on webpage
Fixed in v2.1b
