I have just received a pre-configured meteo hub/cisco NSL box from Ambient Weather, which is connected to a Davis Vantage Vue. I clicked the automatic update to update the firmware to 4.5d.
The data seems to be coming over fine from the Vantage Vue, and I can display it in the meteohub dashboard.
I created a weather station on Weather Underground (KNYITHAC7) and set up meteohub to send data to it. The problem is, no data has ever been received on Wundergound. The station shows up as "active=no" and no data appears in either the normal or rapid-fire views on the site. It has been 3 days since I set it up.
I have looked in the logs on the meteohub, but I don't see any entries relating to data uploads.
Can anyone help me troubleshoot this?
Jeff
P.S. I also am unable to display the data using the WD Live feature. When I click save and display, it loads the Flash applet, then just displays "Loading Data..." forever. I don't know if that could be related.
Problems with Weather Underground upload
