Are these errors normal during startup?
YJB
Post by YJB »
I've started to play with my Sheevaplug, I'm a bit concerned regarding the following messages during startup (from the dmesg log):
[42949374.900000] uncorrectable error : <5>0x000000100000-0x000000500000 : "uImage"
[42949376.260000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949376.260000] Buffer I/O error on device mtdblock0, logical block 0
[42949376.270000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 8
[42949376.280000] Buffer I/O error on device mtdblock0, logical block 1
[42949376.290000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 16
[42949376.300000] Buffer I/O error on device mtdblock0, logical block 2
[42949376.310000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 24
[42949376.310000] Buffer I/O error on device mtdblock0, logical block 3
[42949376.430000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949376.430000] Buffer I/O error on device mtdblock0, logical block 0
[42949388.250000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949388.260000] Buffer I/O error on device mtdblock0, logical block 0
[42949388.270000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949388.270000] Buffer I/O error on device mtdblock0, logical block 0
[42949388.320000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949388.330000] Buffer I/O error on device mtdblock0, logical block 0
[42949388.340000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949388.340000] Buffer I/O error on device mtdblock0, logical block 0
[42949390.470000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949390.480000] Buffer I/O error on device mtdblock0, logical block 0
[42949390.490000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 8
[42949390.490000] Buffer I/O error on device mtdblock0, logical block 1
[42949390.500000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 16
[42949390.510000] Buffer I/O error on device mtdblock0, logical block 2
[42949390.520000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 24
[42949390.530000] Buffer I/O error on device mtdblock0, logical block 3
[42949390.640000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949390.640000] Buffer I/O error on device mtdblock0, logical block 0
[42949393.540000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949393.550000] Buffer I/O error on device mtdblock0, logical block 0
[42949393.560000] uncorrectable error : <3>uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[42949393.570000] Buffer I/O error on device mtdblock0, logical block 0
It seems that I'm only getting these errors during startup, but I want to make sure that I'm running somethign stable before switching from my NSLU2 to Sheeva.
Re:Are these errors normal during startup?
Yes, don't worry.
The errors are related to the file system on the internal flash storage of SheevaPlug. Meteohub does not make use of it.
