What script to use the xml-file?
WS Grave
Post by WS Grave »
I'm not used to work with xml, but could anyone tell me how to convert a line in the all-sensors.xml into actual data for me to put on my site?
I guess it's something like this:
<?php
$dataUrl = 'http://domainname/all-sensors.xml';
$data = simplexml_load_file($dataUrl);
and than what???
Appreciate any help !
Re:What script to use the xml-file?
I would do it the other way round...
Give your html-page to Meteohub as a template and let Meteohub fill in values and loading the resulting HMTL up to your web server.
WS Grave
Post by WS Grave »
It seems that one minute the data are filled in OK, but the other minute not and I get to see the code instead of data for some.
That's why I was looking for the xml-way to do it.
I would prefer the html-way however :)
PS.
Could this be due to low "Hold time for live data"?
I had it set to 60 seconds, but it should be higher?
Post by skyewright »
WS Grave wrote:It seems that one minute the data are filled in OK, but the other minute not and I get to see the code instead of data for some.
It can be handy to include
[blank_the_unknown]
somewhere near the top of your html file. That tells Meteohub to just leave a blank if it can't provide a substitute for a particular value.
PS.
60 seconds is very tight. Just one missed reading for a lot of sensor types? Mine is set to 300, which is I think the default?
WS Grave
Post by WS Grave »
Thanks for that tip Skyewright.
But I probably found it.
I've set the "Hold time for live data" to the original 300 seconds, and since than all data is filled in OK.
I had it set to 60 seconds, and mostly the UV gave an error, which is because of the 1.5 minute update I guess...
WS Grave wrote:Thanks for that tip Skyewright.
Actually, I forgot to mention that there is also a newer, fancier, technique available too. Maybe you've already spotted it?
With the newer technique you can specify what you want to appear if the value is not available, e.g.
[actual_rain0_rate_mm:-]
would each give either the current actual rain rate, or a dash if actual_rain0_rate_mm wasn't available.
