However, it took me a month or so to debug the problem (I wasn't exactly putting my full energies into it). By the time I got it working again, my SLUG wasn't working any more.
I have tried re-flashing the OpenSLUG software (2.3 from the archives right here at meteohub.de) and re-building the 2 GB USB flash drive (using the 4.5 firmware). The problem remains.
I have the station set up, along with the sensors. Setting up the sensors, they indicated they were getting good data, and there is data there when I first reboot the system. However, a short time later, when I look at Sensor Setup, I see this message:
Any time I go to "Inspect Data" there is no data.error connect socket 127.0.0.1:5555 :Connection refused
Warning: Data logging has been halted.
There are no entries in the alarm log, and nothing apparently pertinent in the system log. In the meteohub log, however, there were entries about input/output errors when reading or writing to files in /data/weather. A sample from the log:
So I ssh to the SLUG, and try to check the /data/weather directory. I get odd output:logger (07.11.2009 03:07:21): connect station 0 (WH-1080 via USB HID).
wmr928eval (07.11.2009 03:08:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
wmr928eval (07.11.2009 03:09:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
wmr928eval (07.11.2009 03:10:01): error while opening file /data/weather//seq-min1 for writing: Input/output error: Input/output error
wmr928eval (07.11.2009 03:10:02): error while opening file /data/weather//hist-day1 for writing: Input/output error: Input/output error
wmr928fulleval(07.11.2009 03:10:02): recomputation of weather data started.
wmr928eval (07.11.2009 03:10:02): error while opening file /data/weather//hist-hour1 for writing: Input/output error: Input/output error
wmr928eval (07.11.2009 03:10:02): error while opening file /data/weather//hist-last24h for writing: Input/output error: Input/output error
So it appears there is something VERY messed up about the file system on the SLUG. I can't manipulate any of the files in /data/weather using Linux file commands. For instance:root@meteohub:/data/weather$ ls -l
ls: seq-month1: Input/output error
ls: hist-day1: Input/output error
ls: hist-year1: Input/output error
... (more Input/output errors for different files)
ls: thb1-month1: Input/output error
ls: 200904: Input/output error
total 20
drwxr-xr-x 2 root root 4096 Nov 7 2009 200811
drwxr-xr-x 2 root root 4096 Nov 6 17:47 200901
drwxr-xr-x 2 root root 4096 Apr 30 2009 200905
drwxr-xr-x 2 root root 4096 May 31 17:00 200906
-rw-r--r-- 1 root root 627 Nov 7 2009 hist-alltime
Or, even better:root@meteohub:/data/weather$ rm -rf 200811
rm: cannot remove directory `200811': Read-only file system
I have reached wit's end. Any help will be appreciated.root@meteohub:/data/weather$ rm -rf 200811
-Bill
