Graphs not generated 0 KB
peejay
Post by peejay »
Recently the meteohub application only generates graph files with 0 kB, empty. Anyone seen this before ? (4.5i) Also opening graphs from the meteohub interface gives blank screens.
WS Grave
Re:Graphs not generated 0 KB
Post by WS Grave »
Hi Peejay, I noticed recently that no graphs at all were generated, but that was just around noon (0:00 AM). But only a few minutes later the graphs were allright again.
Did you set the creation time accordingly to the graph?
A graph with every hour content does not have to be created every minute. Maybe check that.
peejay
Post by peejay »
Yes, I do have the graph generation frequency adjusted to the graph content. Most graphs are only generated every half - 2 hours. What I do see a bit strange is the time stamp of the graph which seems 5 min or more off from the time I expect. Is this maybe a clue ?
HeinrichH
Post by HeinrichH »
Try to look at the graphs with the view function of the graph definition. When I have empty graphs there is no data for the specific sensor or the format string is wrong, you get empty files but with the view function you get the error string in the screen
Checking the remote....
peejay
Post by peejay »
Thanks for your remark. I tried this but also using the view function I get also an empty window (while in other case if you set something wrong I get an error string).
marc10k
Post by marc10k »
Hi peejay
Did you find a solution to your problem? I do have the same at the moment.
Marcus
peejay
Post by peejay »
Hi Marcus,
No, i could not solve the problem. So eventually I made a back-up of all data, reinstalled the application from scratch and copied the data back. After recalculation everything worked again.
Peter
marc10k
Post by marc10k »
I tried reinstalling, still the problem no graphs. I had the problem from the beginning and never saw any graphs. I have no clue where to look now.
Marcus
