Hi, I run MeteoHub on a SheevaPlug with 4GB 30Mbps Sandisk SD card. There are three weather stations defined (two RFX receiver and a Davis) plus virtual "system data" station.
I experience steady rise of CPU utilization on the system, now approaching 60%... What can be the reason and what can be done to stop this trend?
It's standard for the system load to steadily rise through the month until the end, but then it resets to a lower level in the first several days of the following month. This is on the NSLU2, but I guess it must apply to all platforms.
Looking at the 3-month chart, I see b_l seems to be right... the load rises through the month and then falls down when the next month begins.
To graph system data, just add a system data virtual station and start collecting data points. The important ones for me are the system load and storage.
I am currently working (time permitted) on a simple plugin to monitor other hosts on the network and use MeteoHub as a generic data collection and graphing engine, plus the alerts to send an email when something goes wrong...
Headworx, you've probably been adding chores for your meteohub to porocess over the past three months so your peak load at the third month is much higher than the peak of the first month.
Another thing that seems to excessively increase my system load is having bad data hanging around in prior months. I periodically use the Cleanup Data button under the Inspect Data section on the current month's data. I especially do this if I've had a spontaneous reboot.
I have 3 weather stations (1 Davis and 2 RFXComs), 6 sensors each (that totals to 18 real sensors + 6 additional for system data). The performance of the system (web interface, graphs...) is very good, I have just been wondering if it will settle somewhere around 50% or will continue to climb through the roof... will see in 3 days, when November ends... :)
Have not used the cleanup data... but have not had any reboots either... Sheeva is rock steady... I'll wait till December and then may be will do the cleanup, depending on the load.
Maybe a stupid question but how do you read those data fields?
When I'm looking at the system info tab I see a system load of 0,54 0,56 0,57 but when I'm looking at the sensor page the processor load is 0,58.
What do those numbers mean?
How did you defined your graph? What's the time bucket and what are the units used?
My graph is defined as a scalar data on a time line, for the last 100 days, with 6 hour buckets. I use data0 sensor for CPU load. Beforehand there is a Weather Station 1 of System Data type defined, that provides the necessary sensors. Pretty standard stuff... I think the graph and values are correct. Today I have 60%, lets see what comes up tomorrow...
On Nov 30 it was 60%.
On Dec 01 it was 18%.
On Dec 02 it was 10%
Today (Dec 3) is 12%
On the other hand my month highs were:
40% in September
50% in October
60% in November
Wonder if the end of month maximu CPU load has to do with the fact I kept on adding sensors and weather station to the system or because the amount of historical data was rising?
Anyway... will see by the end of December... As I have not added any new sensors / weather stations during recent weeks...
