Data misguided in the dashboard? ** solved **
cool_pc
Post by cool_pc »
A column this month, data MAX copy screen below.
Re:Data misguided in the dashboard?
Do you have a wmr200?
If so it might be possible, that you sometimes get isolated strange sensor readings (despite the crc and all this is ok). I am just doing investigation on this. stay tuned...
cool_pc
Post by cool_pc »
Yes I actually owns a WMR200.
OK, I digged very deep into the code and traced some samples... and finally found the bug. This bug causes false sensor readings when in wmr 200 mode under certain circumstances. This will be fixed with the next update... coming soon.
As the next update will not include a repair/delete tool for raw sensor data, this means that sensor data recorded with wmr 200 stations that are impacted by this bug have faulty recorded data that might be hard to correct manually. The most pragmatic way will be to purge the old data.
Sorry for that :blush:
