Error on install ebox 2300
D70
Post by D70 »
Hi Boris
I'm tying to setup a ebox 2300 with Meteohub. When the Meteohub is installing I get the error message "zcat: error inflating"
http://img39.imageshack.us/img39/1700/pb281085.jpg
After that if I remove the PEN and boot from the CF I get the error GRUB Loading... - Error 2
Where is the problem?
One more note, when I boot from the PEN when Linux is loading I'm informed that the "CPU Vendor is unknown and that the system could be unstable for that."
Re:Error on install ebox 2300
zcat error indicates that installer fails in decompressing the image data. please try to setup usb stick again.
unknown vendor message is normal, but with a damaged linux image it will certainly not start properly...
D70
Re:Error on install ebox 2300 Solved
Post by D70 »
Problem solved after make a new USB image.
Thanks Boris
