I set up recently a HTTPS connection for my Meteohub server using stunnel. My server is an HP Thin Client running the X86 Meteohub server 4.5i. In case you might be interessed in, here is how I did it.
Stunnel4 installation
With Debian installer apt-get, this part is really easy. Just pay attention to the 4 at the end of stunnel or you will get the previous stunnel version.
apt-get install stunnel4Edit /etc/default/stunnel4 and change
ENABLED=0Code: Select all
ENABLED=1In order to cypher connections, stunnel must have a SSL certificate. If you don't have yours, you can generate an autosigned certificated this way :
cd /etc/stunnel4
openssl req -new -x509 -nodes -days 365 -out stunnel.pem -keyout stunnel.pemEdit /etc/stunnel4/stunnel.conf and insert these lines :
cert = /etc/stunnel/stunnel.pem
key = /etc/stunnel/stunnel.pemCode: Select all
;[pop3s]
;accept = 995
;connect = 110
;[imaps]
;accept = 993
;connect = 143
;[ssmtp]
;accept = 465
;connect = 25Code: Select all
[https]
accept = 443
connect = 80
TIMEOUTclose = 0Code: Select all
/etc/init.d/stunnel4 restart
