Meteohub fall out on port 80
vecerapl
Post by vecerapl »
Hi, I put weather stations in a box outside and no longer receiving sensors is great without any downtime sensors. Unfortunately, I have a problem with the very meteohub, which I always fall through the port 80 and thus through the explorer to get there. I have to go directly through putty, log data and reboot. He has meteohub port 80 goes right. Unfortunately, this makes me all the time. Evening check data, go to sleep and wake up in the morning and through metehub explorer not start: (
Failure of the graphs came from after 7 o'clock in the morning.
This is LOG errors:
SYSTEM LOG:
2009.12.11 18:54:37 log file cleared by user
2009-12-12T06:25:01.869195+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2009-12-12T06:25:01.888291+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2009-12-12T06:25:01.888543+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
2009-12-12T10:52:37.249044+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2009-12-12T10:52:37.249362+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2009-12-12T10:52:37.249381+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2009-12-12T10:52:37.249397+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
METEOHUB LOG:
logger (02.01.2009 07:31:50): parent process received termination signal (15).
logger (02.01.2009 07:31:50): child process received termination signal (15).
logger (12.12.2009 10:52:37): data logger started.
logger (12.12.2009 10:52:38): connect station 1 (TE-923 via USB HID).
logger (12.12.2009 10:52:38): station 1 (TE-923), hardware version 4.
wmr928fulleval(12.12.2009 10:55:01): recomputation of weather data started.
wmr928fulleval(12.12.2009 10:55:36): recomputation of weather data finished: 35808 records processed in 34 seconds (1053 records per second)
SMB:
2009.12.11 16:06:32 log file cleared by user
[2009/12/11 16:08:45, 1] param/loadparm.c:map_parameter(6110)
Unknown parameter encountered: "disable poolss"
[2009/12/11 16:08:45, 0] param/loadparm.c:lp_do_parameter(7196)
Ignoring unknown parameter "disable poolss"
[2009/12/12 10:52:38, 1] param/loadparm.c:map_parameter(6110)
[2009/12/12 10:52:38, 0] param/loadparm.c:lp_do_parameter(7196)
NTP:
11 Dec 19:50:14 ntpd[1636]: kernel time sync status change 4001
11 Dec 20:58:32 ntpd[1636]: kernel time sync status change 0001
11 Dec 21:49:47 ntpd[1636]: kernel time sync status change 4001
11 Dec 22:06:53 ntpd[1636]: kernel time sync status change 0001
11 Dec 23:49:20 ntpd[1636]: kernel time sync status change 4001
12 Dec 10:52:39 ntpd[1641]: frequency initialized 23.396 PPM from /var/spool/ntp.drift
12 Dec 10:55:56 ntpd[1641]: synchronized to 81.0.239.181, stratum 2
12 Dec 10:55:56 ntpd[1641]: kernel time sync status change 0001
