2009-12-14T13:11:43.145585+01:00 localhost rsyslogd: WARNING: rsyslogd is running in compatibility mode. Automatically generated config directives may interfer with your rsyslog.conf settings. We suggest upgrading your config and adding -c3 as the first rsyslogd option.
2009-12-14T13:11:43.145922+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad immark
2009-12-14T13:11:43.145940+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: MarkMessagePeriod 1200
2009-12-14T13:11:43.145958+01:00 localhost rsyslogd: Warning: backward compatibility layer added to following directive to rsyslog.conf: ModLoad imuxsock
[2009/12/14 13:42:38, 1] param/loadparm.c:map_parameter(6110)
Unknown parameter encountered: "disable poolss"
[2009/12/14 13:42:38, 0] param/loadparm.c:lp_do_parameter(7196)
Ignoring unknown parameter "disable poolss"
