v2.2 no data from [actual_thb0_fc_text] **solved*
cbhiii
Post by cbhiii »
No forecast data is received from the variable [actual_thb0_fc_text] after v2.2 upgrade.
The variable does not appear in the list http://..../meteograph.cgi?text=all
I had to downgrade to v2.1c since people use my webpage and forecast each day.
Re:v2.2 no data from [actual_thb0_fc_text]
Sorry, works with my rigg:
actual_thb0_fc_rule 192
actual_thb0_fc_text Mostly_cloudy_and_cooler._Precipitation_possible_within_12_hours,_possibly_heavy_at_times._Windy.
cbhiii
Post by cbhiii »
[actual_thb0_fc_text] does not even appear in my listing when I enter http://..../meteograph.cgi?text=all
How can it work and not be there?
Question is, why is it not part of your text output?
However, do I have a chance to have a look into your system?
Re:v2.2 no data from [actual_thb0_fc_text] **solv
root cause was a general data logging problem with some vantage stations. solved in update 2.2a.
