problem withh all-sensors.xml after install 4.5x (Build 61)
What's hot...
camerawind
Post by camerawind »
Hello i have installed new version software and now the file all-sensors.xml have this entrys:
<item sensor="lunar" cat="phase" unit="dk">Fuldmåne</item>
<item sensor="lunar" cat="phase" unit="cz">actual_lunar_phase_cz_html</item>
<item sensor="lunar" cat="phase" unit="cz">Úplněk</item>
this is a problem for read with my personal aplicattion, its possible return older version software?
Re:problem withh all-sensors.xml after install 4.5x (Build 6
& chars in XML looks to cause trouble. Next version of Meteohub will purge these lines from XML-output. Info will still be there in plain text output.
rovinj
Post by rovinj »
I also tried to go back to older version, but it was unsucessfull.
