Exportfile EXP01_00.CSV for WSWIN
julsing
Post by julsing »
I'm using Meteohub with WSWIN for some time now without any problems. I use the WSWIN File Monitoring feature.
I noticed that the file EXP01_00.CSV is getting bigger and bigger, consequently it takes longer and longer to do a SYNC RESET, which copies the content of EXP01_00.CSV to import.csv.
I make regular backups of the Meteohub export directory.
Can I delete the file EXP01_00.CSV? I was thinking (though I'm not sure about it) that Meteohub rebuilds the file with new data from the date of deletion?
Frank
Re:Exportfile EXP01_00.CSV for WSWIN
Actual versions of Meteohub do only compute EXP files on request. On "resync" press data generation (with temp file EXP01_00.csv) starts with a maximum of about 40 days in the past from today. When more historical data is needed for WSWIN import, you have to build this manually for the month you need. Resulting monthly files have to be imported manually into WSWIN.
julsing
Post by julsing »
Hi
I'm using Meteohub version 3.3.
I'll install the latest version.
julsing
Post by julsing »
admin wrote:Actual versions of Meteohub do only compute EXP files on request. On "resync" press data generation (with temp file EXP01_00.csv) starts with a maximum of about 40 days in the past from today. When more historical data is needed for WSWIN import, you have to build this manually for the month you need. Resulting monthly files have to be imported manually into WSWIN.
I installed MeteoHub: 4.5i (Build 48), but the permanent file EXP01_00.CSV keeps increasing. It's now 16 feb 2010 and the file goes back to 12 dec 2009 (date of installation). 5 MB now. The resync file import.csv has the same size and also goes back to 12 dec 2009. So nothing changed here. I still have this increasing file and it still takes longer and longer to resync.
Is there sometning I can do?
julsing
Post by julsing »
