Network issue IP address
julsing
Post by julsing »
I have a strange phenomenon on my home LAN. Using ipscan.exe I found that Meteohub has two IP adresses: 192.168.1.16 and 192.168.1.77. The first address I assigned in the network dialog (no dhcp), but where is the other address coming from? I can access the Meteohub web interface via both addresses.
It seems to be interfering with the router DNS system.
Thanks for explaining.
P3R
Re:Network issue IP address
Post by P3R »
Search the documentation for 192.168.1.77, it's assigned by default.
julsing
Post by julsing »
Thanks, I had noticed the posts too after posting!
However, I still have this problem with the DNS.
P3R
Post by P3R »
julsing wrote:However, I still have this problem with the DNS.
Okay.
I doubt that anybody will be able to help you unless you explain what problems you're having.
mds
Post by mds »
I am having a similar issue that can not access the unit at 192.168.1.77 Any suggestions to access so the unit can be flashed to the next version firmware?
Meteohub always assigns 192.168.1.77 as its emergency IP address. So you always have two IPs to reach Meteohub with.
When your router is also using 192.168.1.77 this will in deed make trouble as both system will react on requests to this. Please give your router another LAN IP which is still free in your network. To change backup IP of Meteohub can hardly be done.
