Wind-Direction
la9laa
Wind-Direction
Post by la9laa »
Hi
It seems as if the wind-direction shown is not right according to the Ultimeter 2100 display and other software (WVS and Data-text tool). The direction looks as if it "stops" at around 230-240 degrees. It should vary much more towards 300-360 degs. (See attachment).
Ron
My Wx-page:
http://www.nordbynes.info/andsvtn/Wx/huset.html Image
Re:Wind-Direction
did you try if graphs generated by meteohub do show the same problem?
If so it might be a bug in how Meteohub gets wind direction data from your Ultimeter station. There are just a very few Ultimeter stations runnning with Meteohub.
What Meteohub SW version are you using?
la9laa
Re:Wind-Direction
Post by la9laa »
Hi
The graphs generated by Meteohub and "Inspect-data" does also show the same problem.
I am currently using the 4.6 (Build 67) version..
Ron [file name=error_wind.txt size=1109]http://www.meteohub.de/joomla/images/fb ... r_wind.txt[/file] Image
la9laa
Re:Wind-Direction
Post by la9laa »
I forgot to mention that the wind-direction should have been between 200-360 both today and yesterday. (Mostly between 270-360)
Ron
Re:Wind-Direction
Ultimeter reports wind direction in a range of 0-255. Meteohub has to stretch that to 0-360. Will be part of the next update.
For the time being you can adapt this by a calibration factor for wind direction at Meteohub's "settings" page.
la9laa
Re:Wind-Direction
Post by la9laa »
Thanks again for top support!!
Ron
